julianf
- devon, uk
What about making a small test setup?
You could use an inverted clear bottle, as large as you can easily find - maybe a watercooller bottle for example.
Fill it with water and invert it in another bucket of water, so it does not empty, then pipe your gas in with a little airline under the edge of the top (that's now, of course, the bottom)
You could then get a known (ish) quantity of your feedstock in another sealed container, on the other end of the pipe.
It would be a quick and easy experiment to see how much gas was produced from your particular feedstock - that would give you a way better grasp than random numbers off the interweb.
If you built the test rig in a vaguely sensible way, you could do other stuff like chuck in some of your daily kitchen waste to it also, and see how things changed with regards to output.
I know that, at my partner's old employer, they had one of those big rotary composters, and they had to chuck in sawdust to control, I guess, the moisture / air levels. It may be that doing that gives you a more rapid process or somthing too.
I tried to make it clear before that, if you are to press on, I'd very much like you to succeed.
