Think that should be your starting point. Figure out just how big your "sack" needs to be before getting too deep. (A pun may be applicable here)Put bluntly, if a sack of free cow manure could give me a tank of free hot water it's a no brainer.
My knowledge is limited but I understand the additional of uneaten food waste is big help regarding output? (As well as being able to factor in the disposal cost of food waste)I am installing one at a well known office block in London. That takes the food waste and uses that
My engineering team are designing one for a cattle auction in Wales, this may also get the local schools food waste added to it
boiler and steam turbines are an inefficient by modern standards method of generating power. Many of the old land fill sites and some of the larger cattle farms have the gas gathering that supplies a gas engine turning a generator.So basically you want to build a small CHP.
Heat generation is one thing but generation requires a turbine and a boiler. You're getting into expensive territory in terms of construction and also certification then.
In reality the oil and gas were burn now are just rotton organic waste from eons ago burried and left to rot in an enclosed rock formationHousehold waste in general will make methane, old landfill sites sometimes get clay capped and piped up for methane extraction. We worked on the landscape/tree planting side of things at a big site near Canterbury and one near here that were producing gas to run some pretty big generators . As the ground sinks over the years the tops of these vertical extraction pipes have to be cut down, on one of the sites about thirty foot of pipe was removed over a period of ten years, weird to think that such a large area could sink through rotting rubbish to that extent.
Bob
In days gone by thats how folk kept warm before all this woke culture of central heating. Very common round these parts in the Border Reiver times!move upstairs n put cows in what was ur living room free heat and all the fart gas u can use....hahaha...
great subject..
Methane is a greenhouse gas, don't know if its any worse than the co2 it produces when burned.
Bob
other easier alternatives
Realistically speaking cow manure, or manure of any variety will have value due to the price of fertiliser. So it will probably not be “given away“.How is it easier when already said, the free resource is cow manure, produced on site right where where any eventual "gas" would be utilised?
Bob
