I bought a clutch servo on eBay
Brand new and only paid five quid so a bit of a bargain. The truck has power steering and air assisted brakes so it is quite light to drive except for the clutch which is very heavy. I am not sure why but I think that when the truck was converted to diesel the linkage was changed in some way. There should be (I think) a clutch relay linkage that gives some extra leverage to the pedal but that has been bypassed completely on my truck. An air clutch definitely makes a truck nicer to drive so I will have a go at fitting it once the cab is off.
well done on your choice of oil too, the factory is half a mile from my house
If I remember right Ford beat them to the tilt cab by a long way therefore picking up all the new customers, the D series was nicer to drive too.
The TL came later but if you ever drive a TL the steering lock was poor
I have a Ford D series 16 tonner alloy bodied tipper sat in the yard that's very slowly being restored. LWB with full air brakes and the Ford 6 cylinder turbo engine.The advantage with the D Series tilting cab was you could have one of the 6 cylinder engines out of the chassis and on the floor in less than an hour (the record in our workshop was 25 minutes admittedly for the smaller 4 cylinder engine).
Which reduced servicing/repair costs considerably compared with the TK's fixed cab
Really interesting project, asa BT mechanic these were well liked in the workshop as far as working on them, stub axle pins could be a nightmare but the easiest was was take the front axle off and lay it between two big blacksmiths anvils,BFH and a decent drift and a mate with nerves of steel to hold it, fond memories best of luck
Dev
