I’m struggling to see your post with the coolant tank, but if it’s the standard J&S one the returning coolant flows into the top drawer and flows from section to section making its way eventually to the bottom drawer where the. Coolant and pump are housed. The fluid flows slowly enough that the particles have time to settle out.
Fun to clean out, ask me how I know!
Cleaning them is a flipping nightmare.
The filter paper method is much better although does have a consumable cost.
Other method is to get a very fine sieve mesh, and make a sieve where the coolant flows over a weir, and onto the sieve mesh angled at say 30° from vertical.
This would take out all particles over say 40-50 microns. Magnets in a tube will remove a lot of the ferrous material.
You can then use the 10" water filters with a mesh filter first, then progressively finer filters.
Again a consumable cost.
Wow really sounds like it going to be a fun process to clean mine out then xD
Considering this is for hobby use, do you think it is worth it replacing it with water filter system like @bR39Da mentioned?
So no will have to source 4 new ones (might as well replace all 4) and try again.
Will try and keep assembling some small items in the meantime till I get the mounts and get my friend to come over again
also I'm based in Malta and I don't think we have those shops here.
