Misterg
- North Wales
You'd need ~6.25kg of Sodium bisulphate to make up 25l if my maths is right which should be a lot cheaper than £100!Reason I am asking is I am going to need about 25l of solution and going with the stuff I got from Classic Plating that is going to cost me about £100
e.g.:
All Swim Pool Acid Sodium Bisulphate pH Minus (Lowers pH)
Balance your pool water with All Swim Dry Acid. Easy-to-use sodium bisulphate lowers pH, prevents scaling, and improves chlorine performance.
www.allswimltd.com
Blue Horizons pH Minus Sodium Bisulphate 25kg
Blue Horizons pH Minus Sodium Bisulphate 25kg available online. Supplied with fast delivery!
(P.S. - could you cut the top off something like this for a tank?
I bought it a few years ago to use as drain cleaner, though I've barely used it as it's a bit scary, I don't have a licence and don't remember having to jump though any hoops to get it.
