Gold and white are both nice on AC. Grey work ok they are not quite as good IMO but more noticeable on dc. Personally I don't think you need worry too much. Just get what's available.If i cant get the blue what would be the second best choice gold or grey?
Thanks guys i was going to have another go this evening, but will wait now until i pick up the new tungstens.
Hopefully it will make things a little easier for me.
I do this when using scratch startYou can also flick the filler wire on the job, that will often fire up the tungsten - weird I know, but it has something to do with grounding.
.I do this when using scratch start
The filler is in contact with the job and I flick the tungsten off the filler to start up. This way the tungsten doesn't accidentally stick and cause inclusions on the job.
]Swap torches daz. Rule it out.I will give that a try.
Don't even feel like taking pictures of todays efforts.
They only had green, grey and red tungstens so i got the grey.
Once i get started things are much easier than before if i loose the arc length it splutters a bit and i can tuck it back in and carry on, with the thinner tungsten it would ball.
But still cant get her to start.
Freshly prepped tungsten will start fine.
Scratching sometimes works.
Using the hot start will work but it leaves a nice ring of soot.
I only have the water cooled torch.Swap torches daz. Rule it out.
Hi Kai.Hi all,
I was a little curious how the AC behavier of my old EWM was, so I made some testing today.
Here are the results:
I had the biggest problems with the start of the weld. Not the HF ignition (hotstart was at 2), but creating a nice shiny puddle. That took some time and I have to leave the arc on some point in the beginning to let the cleaning action doing the job at first. I don´t know how to do that on very thin material. I think that it would melt away..
If there is a shiny puddle, than going forward is not a problem.
My 2.4 elektrodes are to small for something like 150A AC the ball is around 3mm diameter.
I will have to try 3.2 (blue or gold)
I realized differences when I changed the settings on the machine, but to be honest, I don´t know which to prefer.
125hz and the balance around the middle works o.k. for me.
When the preparation of the material was not o.k. then I had bad problems with horrible uneven and contaminated welds. I had to clean also the innerside of the profile I used.
Anyway the results are not that clean, the surface is not very even and shiny. Maybe more cleaning or different material? What do the pro´s say?
regarding the torch Darren: I had one that drove me crazy. It was a small (size9) torch and I had to weld some bigger material but was to lazy to change the torch. When it became to hot I put it into a pot of water (great idea, I know). After that I had big problems with corrosion/contamination during the welding process. I changed all the small parts, the gas bottle and the pressure regulator without success and at the end the torch body.
Kai
This gets a lot of people when they first start out with Alu and it's the nature of the beast.but creating a nice shiny puddle. That took some time and I have to leave the arc on some point in the beginning to let the cleaning action doing the job at first. I don´t know how to do that on very thin material. I think that it would melt away..
Daz I don't know what that switch does but it's there on the machine ready to be switched about. Don't be frightened to change stuff it (shouldn't) blow up.Just been looking at the manual again. Whats the variable ignition current (search arc)?? Should this be on 0%?
Its the first button on the left after the button for the pedal/switch.
