BChild
SIP - enough with the mods!!!!
Thanks for posting that diagram Ian . . . makes a lot more sense to me than the one in the manual.
Tony
Thanks for that - It's nice to feel like you've given soomething back
Tony
OK I've bridged the gap with a piece of plastic tube
Not ideal but it seems to stop the birdsnesting
I'm going to have a go at spacing the torch end by changing the washers and electrical connections to get the end of the liner closer
So Plan B
Was
Nut
Washer
Electrical connection
Washer
Wire feeder
Washer
Nut
Now
Nut
Washer
Wire feeder
Washer
Washer
Nut
It's moved the nose of the liner much close to the drive wheels![]()
Are you still running gasless wire? if so are you running .9mm tip? i find they run better with a .9mm tip rather than the .8mm.
Do you mean the bracket at the left of your photo, the one where the two bolt heads are just visible, behind the wires and blue pipe? If so, that bracket isn't there on mine.
There are a few differences between your welder and mine, judging by that photo, but they're both Cosmo 170. I'll try to post a similar photo of mine later so that you can compare.
Have you changed the brace that you added across the wire feed wheels, that you posted a picture of previously? I only ask because I've still got this mod to do so if you've discovered that it works better one way than another, I'd be interested to learn from your experience.
Tony
I've been borrowing pics from elsewhere on the forum - unless I say "this is mine" assume it isn't!![]()
Thanks for the useful info. about the flexing etc.I wonder what the other mods are in that picture? Looks like something has been bolted onto the front of the welder . . .
I found the thread where that photo came from, so I guess those bolts on the front are from the Euro torch upgrade that silverfox did on his machine.
Tony
. . . it's not much to expect to buy a new welder and have it perform out of the box from day one is it??? But if it's beyond SIP's capability to produce one then I'll just fix it's faults and then when it's all sorted I'll send them a bill for the costs.......
PS not joking either - I know I'll get nowhere but it will give me a huge amount of satisfaction and you never know they might start listening to the end user instead of producing shody rubbish that's not fit for purpose![]()
Keep it coming, i'm very greatful for the manual. I guess i could post some pics of my welder for comparison?this is the greatest topic i have ever seen on this site!
Man i need to make some more mods to my Cosmo 170, shame that the welder is in Liverpool and i now live in CoventryKeep it coming,
