BrokenBiker
- Newport, South Wales
Do they have diff locks on them or have they got to be put in as aftermarket?
Diff locks will be aftermarket - I assume you mean actual axle diffs and not centre diff in transfer case.
I think the early D2's were built with an electrically operated diff lock, but you could retro fit the operating handle?, or I may be completely wrong
Land Rover thought the electronics could keep traction off-road but the die hards wanted the manual option.
Discovery 2. Early models have centre diff lock (CDL) fitted but no linkage to the hi-low lever. The later models loose the CDL altogether. The very last ones it was an optional extra, due to demand so may be fitted and will have linkage.
You don't want free-wheeling hubs on a permanent 4WD system, the front prop will just spin and you'll get no traction to the rear unless you keep the centre diff permanently locked.
the disco isnt a permanent 4wd though?
I think the early D2's were built with an electrically operated diff lock, but you could retro fit the operating handle?, or I may be completely wrong![]()
Technically they are, the same as most models since the SIII (last of the part-time 4WD) the traction control will brake any wheel that spins so as long as one wheel has traction you keep going, Land rover demonstrated it by putting 3 wheels on greased steel plates and it still drove forward.
D2 uses the traction control system to brake the wheel that's slipping and ten bring in the opposite wheel on the axleWas this an electric or vacuum (like the LT95) solenoid ? I've only ever had (3x) Range Rovers, 200 & 300 Disco's and 200 Defender so have no idea about the TD5 system.
