Good call Richard.. But no I wasn't actually welding then I just took a quick snap of it as I was sure someone would ask.. I normally have it set between 5 and 8 lots at the bottle it's set to roughly the same.. And by putting the little bell glass over the torch before I start welding it's normally close, poss 1 ltr down.. I do get through a huge amout of gas though.. But I guessed it was down to me having to re do so many welds..The picture you posted with the regulator and flow meter, does the pea shooter flow meter feed the torch and was it being used when the photo was taken?
The reason I ask is that the flow looks to be about 2 lpm in it and I had trouble with steel once. It would spit when welding due to not enough gas coverage which in turn contaminated the tungsten and made things worse. Tried cleaning etc as you have and nothing worked until I noticed the gas flow was too low and turned it up.
ok will try some when I'm up and about tomorrow.. XNoods I know your fed up mate but there is something clearly wrong with your set up not your welds! Doesn't matter how good you are it's just not goin to happen. Please show us some beads on plate.
Will do give everything a wriggle .. Annoying.. Yet to get a good weld from a brand new welder in a year.. Mind you it's likely to be me I guess .. Lol xAs said, try wiggling the torch / torch cable / gas hose where it enters the torch when laying beads...could just be a bad connection inside the torch or a hose kinking when your doing joints but not beads on flat plate...sometimes its something annoyingly simple, albeit hidden from view...
Thank you.. I hope so too.. I watch the videos on line etc, people using the same kit and they have no issues whatsoever regardless of which joint they are creating, lovely runs of weld, clean and strong.. I keep hoping I will see something someone is doing that I'm not, but no, well not yet anyway..Really wish I could help, I am self taught and sometimes I feel like giving up, usually after I do something silly the list has been long: broken gas connector where the gas enters the touch cable at the welder, wrong polarity on AC, forgetting to re attach the return clamp after moving the work each time it has been something obvious, but not to a beginner.
It is like learning to drive, so much to think about all at once, little by little I am getting into gear. My concerns now are freeze lines, or lack of them in the filler on thin stainless. When I look back at some of the scrap metal under my bench and remember how happy I was just to be able to lay a autogenious run I smile and think I have progressed.
All the best and I hope someone will be able to help you.
The difference is have you bought a Tig welder with the intention of learning. I can't play the piano and I've not bought one to even attempt it.I can't Tig weld. I don't think I will ever Tig weld. I don't care
There are thousands of other skills and things to play with....
Even by trying a single lap joint it's messy and crap.. Gas from elmdale .. I've used a diamond tip cutting wheel and a bench grinder to sharpen rods.. No changes really what ever I use.. View attachment 64729
This is my tig.. Earth lead to right lower... tig torch gas connection to centre.. Tig torch conn left lower. And just above that gas in connector ..
NOODS
Ain't that the truth!! I enjoy TIG but it requires dedication and real perseverance.Oh!! If I lashed out the reddys on expensive kit I'd make sure I learnt to use it. You could of saved a few quid and bought a little mma set. Tig is an art and I've read all too many posts from people that buy the kit expecting blinding results from a day in the shed. For most of us that's just not going to happen. I spent days as an apprentice running straight lines (no filler) on a plate. I then spent more days doing the same with filler, I then moved on to butt joints, the outside corner etc etc it took a massive amount of time to get half decent and a lot of critical points from the good gents that helped me out. Im 15 years into my welding career and I'm still not to the standard of some people (check out tig Paul's work) his welding is simply fantastic. The point is tig is an underestimated process and for a newcomer to get there machine and attempt a inside/outside corner , pipe joint of any sort is destine for disappointment. If it was that simple we would all be tig welders and the rates of pay would be equal to shelf stackers at tesco.
