Glad to be of service, hope it all made sense.
Lovely as usual langy. For some reason that seat stand is the nicest looking bit yet to me. Rest of it's pretty damn nice as well but that side bit is well tastyBit more progress, while I was making the seat sides I kept looking at the seat stands, i've been a bit undecided what to do with them, obvious choice was holes which would lighten them considerably but that was too obvious for me so I came up with this shape, this lightens them a lot but I didn't like that you would see what was under the seat as I will probably have the fusebox under there, anyway I backed it with a piece of 20swg aluminium sheet, Its now light but covered and is different.
While fiddling with the seat my mind was turned to thinking about harnesses and how to anchor in a truck, Harnesses are a bit tricky in a truck as its difficult to get the shoulder straps to run at the desired 20 degree angle, first I put in a crossbrace 4" off the floor, this is on flanges so it can be removed easily, a short piece of tube was added in the centre on a plate which conveniently sits just above the centre crossmember so bolts down easily and takes the righthand belt strap, the left strap bolts into the cage hoop basemount, A 7/16" bung was welded into the tube and gussetted for the straps to connect to.
I started fitting the Pirelli webbing on the seats but run out of staples !!!
Lovely as usual langy. For some reason that seat stand is the nicest looking bit yet to me. Rest of it's pretty damn nice as well but that side bit is well tasty![]()
I prefer the second one but it might not look so nice if you put something under there. I really like your attention to detail with this build; you're only going to see that panel when you get in but you still must get it perfect. Why do you keep welding up off cuts of that fairlane grill - Do you just not want to buy any more or is it not available?
Keep it up.
That's insane
Someone with a CNC laser could make a mint though.
under seat boxed in would make nice tool box, picnic box or built in cool-box
One if those eureka moments!Managed to make a decision last night so I'm scrapping the seat supports, had an idea come to me last night in a dreamStay tuned !!!![]()
Shame but just not happy with how it turned out but these bits will get used elsewhere at some point no doubt.
! But still wouldn't be an original
