octo0072000
- south yorks
I actually like to cross the drawbar, or even put a whole turn around it if I have the slack. It helps to keep the wire from pulling tight on one turn and dangling close to (or on) the road the other. I guess if you only have to tow one thing you can make a reasonably tight arrangement but I have to tow a myriad of trailers and the lighting wire is usually quite loose.
best way to sort your problem Pete is to use coiled wagon susies with plugs on trailer and towing vehicle and keep the susies in the towing vehicle not on the trailers
