Hi Paul, did you ever get any further with this? I bought this welder a couple years ago. Hardly used it and just out of warranty the feed stopped working. Annoying as I just can't justify spending out more money on a new MIG for the amount I use it
Hi DaveA word of caution - some of these Chinese boards use a weird latching relay to drive the main (contactor) relay. Make sure that you get the right type!
I have no idea why they do this, it only increases the component count. I have rewired some boards a while back to accept a 'standard' non-latching relay but I can't remember how I did it.
Dave
no answer to this???
Hello Guys, I am a newbie in this forum.
The problem is inside of the relay JQX-29F-A. This at least worked for me. The wire is open circuit in the coil of the relay.
When searching for this relay, I have found that no one provides them right now.
But the relay is easy to disassemble and rewind.
When unwinding the wire I have found water in the middle of the coil winding. The wire was kind of rusted at several points and at these points it was interrupted.
I think humidity soaks inside of the relay due to temperature change and can not get out. I made some holes in the plastic cover in order to keep humidity out.
Hopefully dust will not come in.
I hope this will work for you as well.
Good luck Martin
hi im new here just happen to buy ozito mwr 135 . mine is same it clicks no feed no spark i open these big relay and lots of moisture insode and the coil is open . other than rewind whats the other option?
