Hmm, a pity he didn't post more details once it was sorted. Good manners and all that...
This should do the job, a fairly cheap encapsulated version:
http://uk.farnell.com/myrra/44197/transformer-3-2va-18v/dp/1689077
So long as it will fit on the board.
And this one, a heavier duty job which Scott posted, with a bit more in reserve:
http://uk.farnell.com/pro-power/ctfcs6-18/transformer-6va-2-x-18v/dp/1780872
If this one is too big to fit on the pcb it could be chassis mounted on a plate nearby, as Scott suggested.
I will tell you a little about what ive done so far to check this problem 100en turbo
Wire feed problem, no wire motor power.
Connected 12v on motor and its fine.
Checked continuity on trigger/gun and the circuit their is fine, no broken connection from trigger to welder.
So this pointed me finaly to the PCB. I checked resistance on the potentiometer and it goes up fine from 0-7 then it drops down to near enough zero, despite going higher. Would this be a problematic pot?
Im thinking I would sooner replace individual parts on this PCB rather than pay £40 for a whole new one.
Though looking at the schematics of the back of the board, it looks to me like the pot affects pretty much every aspect of the board.
I obviously just need to identify the wire feed part of this pcb and replace the faulty components with that part.
Or??? Am I wrong..? Do you know what vital components I could change to repair this board to get the wire feed running again, or is their no point, is it a whole new board?
Or? Am I barking up the wrong tree altogether? Is it something else ive missed and not mentioned here and checked myself?
Can you help? I could mail you a pic of the pcb if it helps you figure it out better?
sapwood@hotmail.co.uk or call 0191 5815340
Im sure theirs a drink in this for you mate.
Heres the boarb pics if anyone could circle whats what, diodes, transistors, transformer etc etc. Im not the best at this, for a sound engineer you'd think my electronics would be upto scrathc. But hey ho, my equipment usualy works, so all I ever have to do is PLAY!
Have you checked out the transformer windings already?
Diodes and particularly transistors generally have to be disconnected from the board to be tested properly.
They are generally cheap enough to replace. The transistors are the stripey ones in the black rings. The striped bands represent values, as you probably know, so if you find a duff one you must replace with one of the same coding value. If you are testing them you need to know the values, in case any are in the process of breaking down. If they are open - no reading at any setting - then they need replacing.
There is probably only one diode in there, as marked in the blue ring. That should take current one way only. If it does anything else, like both ways or nothing, it's shot.
The big flat job in the bottom of the pic is the transformer that had to be replaced in mini mad's m/c, I think. You say you have already checked the relay, too? The box on your left as you look at the pic.
The big fat cylinders with shiny tops are caps, they sometimes blow, but it's usually obvious.
Like you, I haven't got into this circuit stuff in a long while, but when its necessary you gotta try to recall all this stuff...
You could try removing that one resistor and testing it on its own, but check what value it is first. Some have a high resistance. Most of those components ringed in black are actually only resistors, but will still stop the m/c working properly if they pack up. Cheap to replace, but job has to be done carefully, without overheating other components nearby.
