ok thankyou very much for the help is it possible to have the transformers rewound like refurbished if not is there and one in particular someone could advise ?
2x15 means there are two 15V secondaries. They can be wired in series for 30V or in parallel for more current.
15V will give about 18V for the relay, might not be enough to hold teh relay.
That part the assignment of the pins is different and the spacing is probably different. Like I said, finding one that meets the physical layout is difficult.
also how can i find out what the (va) is as there is lots of different ones like 3va or 4va but still have the same power inputs and outputs
sorry to keep hacking your brains
Don't know if 15v would be powerful enough to trip the relay. Probably. Maybe Scott could take a look at it if he's around, as he knows more about these than I do.
The '2x15' means it has two 15v outputs, -15v and +15v. You only need one output so far as I know.
Basically the same but encapsulated I think, and with 18v.
Edit: Whoops, Scott's there already! You'll have to write up an how-to on this problem Scott, it seems to come up now and again with these small Clarkes.
No, it is just the maximum you can draw out of it before the transformer burns out. If you draw less, then it runs cooler.
One of the reasons these fail is the transformer is the minimum size and runs hot. The hotter things run, the shorter they last. The main reason is the wires are real thin and will corrode and break (notice rust on the transformer core.)
yes i understand what you are saying now i think i will order that one which u posted a link on earlier because it would be better for things to be cooler
right so deffinatly go for the 18v one then but the 1x18 or the 2x18
i just wasnt to give myself the best chance to start off with as i dont really want to keep pulling the electrics apart as i know nothing about it
