Prior to you mentioning the ring 100w bulbs a friend recommended them so i went and ordered 2 sets of ring rally sports 100w h7 for my car, quite cheap as well!
But for arguments sake are there any other bulbs people recommend?
I had osram nightbreakers h4 previously and they were ok but i still felt they lacked.
I tried a set of cheap hid's and thought they were worse than the osrams.
........Tysonn i drive a 1990 gti cab ,daily driver for 5years 150k just done a top end re-build due to valve stems leaking ....still got a 89 scirrocco in the shed too ....pull the lift pump out the tank and check for crud....quite common due to filler pipe rusting ,and fit new copper washers to the high pressure pump banjo ,they can be a pain otherwise.....sorry Anto
got some Hella's with slim shell's which only just fit.
....i do remember checking the volts at the bulb with the car running was less than 11volts ,common problem on early golfs,installed relays to get more voltage made a huge difference,not sure if Pugs have a restrictive wiring loom but worth checking
