addjunkie
- Northumberland. Reet oot in the sticks
That type of boat…Mastercraft is used for water skiing and wakeboardingWhat is “the season “ racing?
I've yet to take off a failed alarm, I have however taken off a few that were fried by **** poor installs. High resistance connections being the main culprit where they've been installed with insulated terminals from the local market, bodge locks, and solder gobbed on.The best thing you could do to a Datatool alarm is cut ALL of the wires. I've had to personally remove three failed ones from different bikes.
Versus I've had 3 bikes fitted with Datatool alarms and the only problem I had was when the sounder failed on the oldest.The best thing you could do to a Datatool alarm is cut ALL of the wires. I've had to personally remove three failed ones from different bikes.
Did you find somewhere to squeeze the earth rail in?.Getting rid of a load of 48 year old stuff to be replaced with more up to date gear with the custom loom.
View attachment 538718View attachment 538719
De-pinning the old TCI connector blocks so that they can be remade with new terminals.
He's bringing the seat and tank over on Monday so that I can see what the space is like. I suspect it will either need the coils moving elsewhere or another box fitted behind the battery box as there's quite a bit to wedge in and with things like the coils & reg/rec generating heat and interference I don't want it all rammed together.Did you find somewhere to squeeze the earth rail in?.
He's had his breakfast, a walk, a run round the grass, a big chew thing and thrown himself into his 'workshop bed' in a sulk. Normally he'd be at home on retirement hours with Barbara, so an early start to a place of work does not fit in with his ideas for 'living his best life'.It's the second breakfast which will be the problem, get another organised and normal relations will resume.![]()
He’s a Labrador, they always do their Oliver impersonation!He's had his breakfast, a walk, a run round the grass, a big chew thing and thrown himself into his 'workshop bed' in a sulk. Normally he'd be at home on retirement hours with Barbara, so an early start to a place of work does not fit in with his ideas for 'living his best life'.
Bloody great pampered ponce that he is.![]()
Yeesh that’s dreadful!That's just plain nasty. Time to replace the condensers and replace the low tension ignition wiring.
View attachment 538866View attachment 538867
NRP for most stuff, for out of production/oddball/rare parts are a matter of scouring the 'net. Link to NRP.Here's a question, where do you get mikuni spares from, specifically a set of diaphragms that don't self destruct?
Close to 50 years of ageing wiring with the usual DIY type 'repairs'.Yeesh that’s dreadful!
