- Birmingham
In the 3rd pic, what's caused the insulation damage to the white wire?, heat from the dogs dinner joint or abrasion.
I don't know as yet, unsurprisingly it's not as straightforward as just the powerbox connections. There seems to have been quite a bit of fiddling about with the wiring behind the headlamp, and I have my doubts about the bar switch set up too.In the 3rd pic, what's caused the insulation damage to the white wire?, heat from the dogs dinner joint or abrasion.
Just use all the same colour - when you make it, you run wire from connector to connector, so it's easy to do. If you want to really help, use masking tape looped around each wire and write on some form of ID in a pen type that partically fades at least.Change the colours of a couple of wires inside the harness to give someone a headache fault finding 20 years down the line![]()
The same colour wires (all black) are exactly what Meta did when installing bike alarms 20 years ago. Then attach the other end ‘somewhere’, ensuring continuous work for someone like @CatoJust use all the same colour - when you make it, you run wire from connector to connector, so it's easy to do. If you want to really help, use masking tape looped around each wire and write on some form of ID in a pen type that partically fades at least.
Then it'll be even more annoying that the Id was once there, but now . ..
TBH I'm kept busy by the shaved monkeys fitting them and working on the electrics rather than anything to do with the wiring or kit fitted.I think most aftermarket alarm/immobiliser manufacturers used all black wires, at least it keeps @Cato busy![]()
All black wiring is a requirement for Thatcham approved alarms.I think most aftermarket alarm/immobiliser manufacturers used all black wires, at least it keeps @Cato busy![]()
The Thatcham approved, factory fitted alarm/immobiliser in my 98 Jeep GC has all black wiringAll black wiring is a requirement for Thatcham approved alarms.
I've got serious bobbin-envy!
That genuinely is interesting.Just incase anyone is interested, the large lump on the pitman arm is to reduce vibration on acceleration
What is “the season “ racing?Not actually in the workshop, quick site visit to give this a pre season service
Only required oils and filters this time
John Carpenter, of Mistral Engineering , always used to refer to it as ' Defective Owner Syndrome'.....TBH I'm kept busy by the shaved monkeys fitting them and working on the electrics rather than anything to do with the wiring or kit fitted.
So many times/things you hear this alarm, that lighting or whatever are rubbish/unreliable, then you see the bodge locks, solder, twisted wires, random supply spliced into etc. and realise that the alarm, tracker, ecu, LED controller or whatever aren't where the problem lies. The people who work in tech support/warranty for Boyer etc must spend most of their day sobbing in a corner.![]()
Just had a bloke ring up who has an accessory junction box that he wants to be powered by an ignition on feed. He said it's got a datatool alarm and his mechanic didn't want to do it in case he cut the wrong wire.
It's a motorbike not a nuclear warhead, what did he think was going to happen?![]()
