The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
I know, I have ptfe jawed clamps to do that. Dam handy tool.Shock absorbers too as you need to hold the ram while torquing the nut
These items are Snap-on torque adapters used for accessing difficult fasteners.
- Designed for use with a torque wrench when standard sockets cannot reach.
- The specific adapters shown appear to be the Snap-on 3/8-inch drive 3/4-inch (19mm) bi-hex (12-point) obstruction torque adapters, possibly part number S9513C or FRDHM19.
- They feature an angled, "obstruction" design to clear surrounding components, such as when removing cylinder head bolts without dismantling other engine parts.
- Made from special heat-treated alloy steel for durability and strength.
- The center-to-center length is a specific measurement (often 2 inches) used for accurate torque calculations.
So you claim.
Ford Pinto springs to mind, or have I imagined that?
Last time I used those tools was on a Vauxhall Magnum Engine.Yes, I mentioned that, although that was an open end, not a ring to do the locknut, as you can't get a ring on.
I still want some, although I haven't laid a spanner on a pinto for about forty years.
It's terrible when your danglers broke
Ha ha! So you did! That'll learn me to read posts properlyYes, I mentioned that, although that was an open end, not a ring to do the locknut, as you can't get a ring on.
They wouldn’t work on a Pinto lump , the crows foot needs to be open end to fit the locknutI agree. So heads can be retorqued without removing the rocker gear. And setting the tappets on pinto engines IIRC. Handy for other things too.
I don't have any of those, because I don't need them, but I still want them.
What size(s) are the hex ends?View attachment 524582
Litchfield 1/2 inch drive offset extensions? Anyone know what these would be used for
I bought one of those because I thought it might help split the gearbox from the bellhousing, but the orientation is wrong.Last time I used those tools was on a Vauxhall Magnum Engine.
Sounds like a 747 when on full chat, I was surprised how noisy it was.Lidl had Die Grinders (or "Straight Grinders" as they call them) so I bought one, along with a digital angle finder for £3.99. They had digital calipers for £3.99 as well, but I've got one of those and don't use it much. I haven't tried the grinder yet, but notice that it also has a switch at the far end rather than the angle-grinder-style "trigger" that I'd prefer. I'd like my spinning-at-30,000rpm thing to be easier to stop.
They can't be used on every car, because of the spring and rubber thing around unfortunatelyI know, I have ptfe jawed clamps to do that. Dam handy tool.
I wanted to buy something, so requested a customer service call, he confirmed it must be a technical error, theres nothing he can do about it, and the extra refund is mine - it wont be taken back.An unexpected £72 refund from Amazon, for an item I still have, which has not been returned or requested.
However the same item, I bought in October. In November they changed the price, 30 quid cheaper, so I bought a second and returned the first, still in unused condition, on the last day of the return window I should add.
I decided the new price was good enough to keep two, so ordered a 3rd, a couple minutes after the return was sent off, which I recieved a couple days after doing the return. So it is impossible that I have mixed up the 3rd pair and the first order.
Its the 3rd one they just refunded me for. I hope they are not going to mess about trying to charge me again for the first one!?!
When I check the first order it shows as in transit, while the 3rd shows as return recieved.
Never found one yet.They can't be used on every car, because of the spring and rubber thing around unfortunately
Crack the shock nut with an impact gun before jacking up the car. Loosen it until it is past the nylon nut insert.Never found one yet.
I know how to remove shocks, TVM.Crack the shock nut with an impact gun before jacking up the car. Loosen it until it is past the nylon nut insert.
The only time I've needed to clamp the shock rod is on struts already off the car.
You can clamp onto the part of the rod that never goes into the shock body. So it doesn't matter if you damage it.
11/16 E3320 and 5/8 E3326They wouldn’t work on a Pinto lump , the crows foot needs to be open end to fit the locknut
Are you claiming it as TYA slop, then?So you claim.![]()
using an impact gun can spin the rod and loosen the lower nut inside the strut or even undo it completely. Guess how I know! I now always clamp the rod to stop it spinningCrack the shock nut with an impact gun before jacking up the car. Loosen it until it is past the nylon nut insert.
