Ha ha I was waiting on someone saying that
It is fine, I have put some adhesive lined heat shrink on the cable where it exits the gland and had it bent at the 90 degrees whilst setting. That way the cable coils correctly out of harms way when the stand is up and lets me keep the cable as short as possible.
Can't as it will be in a different position every time I rotate and also the foot will be at a different angle depending on the terrain.
That looks really satisfying. What was the spacer for ?Needed a spacer.
But didn’t have the right tools for it.
So did it in my way ;-).
Working really flawless.
parted 12mm, tapped 1/2" 20 UNF, fits a treat.
All saved from the skipLovely batch of Lista tool cabinets you have there.
I make them 1/2-28, interesting yours is 1/2-20Made a doodaa for the end of a PCP air pistol to protect the silencer adapter thread.
Already had some brass bar and telly was killing me so an hour of relief fiddling.
25mm OD, bored 11.5mm, bit of knurling cos I like itparted 12mm, tapped 1/2" 20 UNF, fits a treat.
View attachment 522719View attachment 522721
View attachment 522722View attachment 522723View attachment 522724
Can't beat brass for cheap bling![]()
Gold is better.Made a doodaa for the end of a PCP air pistol to protect the silencer adapter thread.
Just lighting, both standard 10x16.5 tyres that I refuse to put anymore that the minimum 60psi in with safety squintsAre those tyres supposed to be the same size? Or is it just a trick of the light?
Mine are a different brand/style, and you can move the link bars to (2) different positions.I made the track links lose again however they're both a link too short so they most definitely don't fit like previous owner said!
Believe they're loegering f series steel tracks but not 100% and it's not gonna be easy acquiring 2 links.
View attachment 522800View attachment 522801View attachment 522802
