That table's clean enough to eat Christmas dinner off .View attachment 522196set up the rotary table to get production run View attachment 522197started !
Small cable tie around the neck?It is the neck part that I would like to be the softest as when the stand pivots the 85 shore can leave a small gap which muck could get in. I was trying to think of a way to achieve the soft/hard transition but as the pour gap is only 2mm wide it couldn't be done in a single pour.
I could possibly cast up the neck first in a small mould then transfer that to the normal mould and pour the harder stuff and give it a go but I think I will see what the 40 Shore is like first. I say 40 shore as I was thinking 50 might be better but seems they jump from 40 to 85. The thing is however as both the 40 and 85 are the same make/type I should be able to mix to get something in between if I think it is needed.
That is what I use on the Chinese rubber boot but I have to sand the edges all over or it just cuts into the boot.Small cable tie around the neck?
I put it on the radiator for curing, is that what you mean?Can you heat it a bit after pouring like you see the wood workers doing with those epoxy pours to degas them?
Not sure what you are meaning, well I understand vacuum but how to achieve I don't know.Or a Henry to create a partial vacuum?
No, I have no idea how TPU compares to the epoxies used for tables but I've seen people pouring epoxy using a blow torch to go over the epoxy after is been poured to degas it (bring the bubbles out).I put it on the radiator for curing, is that what you mean?
Probably the low temperatures at the minute causing moisture/condensation on the steel mould.May be useful
Why are there bubbles on the surface of my rubber mold?
Bubbles that appear on the working surface of a cured rubber mould can compromise the fine details and render the mould unusable. Bubbles can ...www.benam.co.uk
16 deg C in the house and mould is acetal. No issues with the 20 shore although the 85 shore has very slight bubbles on the flange, the rest of it is fine.Probably the low temperatures at the minute causing moisture/condensation on the steel mould.
Do you need to apply some kind of mould release? I was looking at polyproylene to avoid using a mould release spray for a future project but I'm sure I could get a better finish machining acetal.mould is acetal
