Or powerwasher with a rotating nozzle ( a large power washer) and then Phoso when done.why not give up on the sand blasting and clean it off other ways?
wire wheel in a grinder? flap disks ? and needle thing (I've not used one before, but few people here like them)
I appreciate the advice I've bought a cheap and nasty pot I just want to know what's the best compressor to get with the pot I have I understand it's going to take a while unlike a lot of people I don't have the funds to do what everyone is asking I'm buying what I can affordI have two 3kw compressors. Both are wired with 16a plugs to dedicated, probably, c curve breakers.
One of them (alone) will run my blaster, but the radius of the "impact zone" is very small. You would be there forever doing the underside of a car.
Ive got a landrover front axle to do. It will take some time with just one of the compressors. I need the other compressor to run an air fed mask, as the axle will not fit in a cabinet here.
Ive got some landrover bulkheads to do. I wont even attempt to do them until i fix my hydro-vane.
More air means larger nozzle size, which means that the radius of your stripping area is increased.
3kw / 24cfm (claimed) will work, but you will just be there forever.
And, as above, you will need some breathing apparatus, as the bottom of a car is not going to fit in a sealed blast cabinet.
Every time i skim this thread, people seem to be saying you need "more" and you want to battle on with what you have, or what you plan to have. Which is fine. But theres not a whole load of point in asking for advice if youre planning on ignoring everything said! : )
You will be able to strip material, but, with your current plan, it will be so very very slow that you'll just hate it.
Cheap blasting is ok for small things in cabinets. But thats not what it seems that you are trying to do.
This isnt some "gate keeper" comment - more just a warning. By all means, crack on with your plan, but what you have been told is true, irrespective of if its what you wanted to hear or not! : )
Can understand your position totally. But you have been told by experienced people, (I sell the things for a living) the minimum you need. If that isn't doable on your budget. Then there will be a cheaper options. It may take longer, and you might have to work harder. But what you want can be done. You are very new on here, please listen to the very sound advice posted.I appreciate the advice I've bought a cheap and nasty pot I just want to know what's the best compressor to get with the pot I have I understand it's going to take a while unlike a lot of people I don't have the funds to do what everyone is asking I'm buying what I can afford
I am listening but I just cart do what people have said I am very new to all of this and I do appreciate everyone's advice I really do as it helps out a lot but unfortunately my budget for a setup was 500 I've bought a cheap pot off eBay for 100 I'm left with 400 to get a compressor I am not to bothered about it taking longer if I had the money I would of just paid a company to do the jobCan understand your position totally. But you have been told by experienced people, (I sell the things for a living) the minimum you need. If that isn't doable on your budget. Then there will be a cheaper options. It may take longer, and you might have to work harder. But what you want can be done. You are very new on here, please listen to the very sound advice posted.
You can't expect someone to advise your use case as there is no compressor suitable with your limitations, give up portability and get a 16 or 32 amp socket fitted you open up used options that have already been recommended. You are asking strangers to recommend how best to waste money you don't have plenty of, maybe take the £100 loss instead of potentially wasting another £400. It's unlikely that not being able to blast your floor is holding up your project, perhaps start a thread with pistures of what you are dealing with and your plans and expectations.I just want to know what's the best compressor to get with the pot I have
A pair of used 3kw belt drives could be had for £300 (£150 each) on a good day.
My two cents worth.I am listening but I just cart do what people have said I am very new to all of this and I do appreciate everyone's advice I really do as it helps out a lot but unfortunately my budget for a setup was 500 I've bought a cheap pot off eBay for 100 I'm left with 400 to get a compressor I am not to bothered about it taking longer if I had the money I would of just paid a company to do the job
