Cato
- Birmingham, UK
What lengths are the runs? If they're a foot or so you could use clear heat shrink over braided or copper earth cable.It's an option if I can't find any automotive cable![]()
7mm on Amazon for example.
A loom's around the £80 - £90 bracket but the problem with that is that the labour to install will be in addition to sorting out the terminals & flying leads from various bits.Have a chat with the owner, they may decide to get it done properly all at once. How much would a new loom cost if available?
Usually, an observation made to the air about there being too many chiefs here and not enough indians, gets the point across.We were well into a breakdown due to a PLC problem in the 80's when a suit turns up and starts getting in the way, one of the sparkies told him to eff off as he was hindering the job, which he did. We got the machine away then our foreman said "did you know that was the site maintenance manager you told to eff off"the manager came over and said he didn't mind as he knew tempers could get frayed due to the pressure.
I found similar on my Bantam wiring, it's positive earth but previous owner must have had their negative earth hat on when connecting the output of the rectifier to the battery so the wiring shorted out the rectifier, luckily it tests OK.
You're looking at a new (expensive) stator![]()
The connectors and replacement reg/rec arrived for the 3TA so the stator, reg/rec and battery wiring is sorted and all in the right place now. Which means I can move on to the wiring in the headlamp cowl and to the switch.
First thing is to work out what in the name of Temu has been done. That meant dismantling the headlamp cowl, which means disconnecting the brake cable, head tensioner etc.
Once in I confirmed that the stator feed dedicated to the lighting was just cut (circled in blue) and taped up doing nothing. Leaving aside the various link wires and feeds for a moment, power for the head and tail lights has been picked up from the battery/general supply via the orange wire into terminal 11 (topside of switch) with an external link to terminal 8 topside.
The upshot is that there's one stator output going via the reg/rec to provide DC to the battery for charging. The other feed which should provide a direct AC to the lighting circuit isn't connected to anything. I have no idea why that would be the case other than it wasn't covered in the 'Fischer Price My First Electrics' instructions.
In theory it's remove the erroneous extra orange wire and connect the yellow stator feed. The concern is what else up/down stream has been changed, disconnected, bodged that's going to appear when I do. What fun!
That mess has gone and already been replaced with a lovely new loom section.At least the new stator will come with the full length of cable so you can do away with the current mess inside the housing.
I couldn't test anything until I'd got rid of the solder blobs and shorts, and it wasn't feasible to do a temporary fix for testing.
I take loads of pics before dismantling or disconnecting anything. Partly to show customers what I found, but also so that I can put things back in the right order.The manufacturers don't help matters themselves sometimes, though.
When I was fixing up the DT50MX I bought for my daughter, one of the things it needed was a new headlight cowl. So all the wiring inside had to be dismantled.
It was all colour coded though, so I didn't make quite as careful notes as I should have. They'd reused the same colours for the kill switch and the headlamp main beam. Getting those mixed up didn't help either the ignition or the lights to work very well. Once I realised what I'd done, after several days of head scratching, it fired up first kick.
My step dad had two MF35s, which I got tasked with sorting out and selling when he couldn't manage them any more.I found similar on my Bantam wiring, it's positive earth but previous owner must have had their negative earth hat on when connecting the output of the rectifier to the battery so the wiring shorted out the rectifier, luckily it tests OK.
Keeps you on your toes doesn't it?My step dad had two MF35s, which I got tasked with sorting out and selling when he couldn't manage them any more.
One was a 3 cyl diesel, with the original dynamo and control box, so positive earth.
The other was petrol/TVO, the original wiring got destroyed in a fire years back, and had an alternator grafted on, parentage unknown, so negative earth.
Both had knackered batteries, so needed a jump start. I had to really double check which one I was dealing with before I attached the clips! Never got them mixed up, fortunately.
Still, I must be getting close to finding all of the bodges now?
My strategy now is to stop looking.Got to love an optimist.![]()
My view may be somewhat skewed based on what I see through the workshop, but I'd rather walk.So you'll be getting rid of all the Jap bikes and getting yourself a pudding basin helmet?![]()
