Mine does help a bit but far more successful is a pedestal fan. Or a desktop one. Really pulls or pushes the hot air into the room. Just turn it off when putting wood inAre the little fans that sit ontop of a log burner any good?
yes they blow air out from any stove pushing it into the room the stove does this anyway within reason but the fans push air even faster which in turn warms the place up much fasterAre the little fans that sit ontop of a log burner any good?
I have a fan assisted barbecue and it really heats up quickly when the little tiny fan runs.Are the little fans that sit ontop of a log burner any good?
they do work without costing the owner any electricI've not heard a good explanation as to how they improve thermodynamic efficiency. And I hate it when people have them in their houses as the directed airflow irritates my eyes. Some people who like them swear by them though so...
I point mine at the flue, from the side,
as goes for there thermodynamics they do use it rather well they push heated air from around the stove into a larger room therefore warming the room up far faster
Explain how.as goes for there thermodynamics they do use it rather well they push heated air from around the stove into a larger room therefore warming the room up far faster
You won't extract any extra heat from the wood or coal burning but you will lose less heat up the chimney. Also it depends on the woodburner location. If against an outside wall you will reduce the amount of heat soaking into the wall and reduce the amount radiating outside.Without figures to back it up, that's merely opinion.
all stoves are built basic 4 walls if they are fitted with convection sides they are improving the flow of air being put into the room from the stoves via convectionExplain how.
I.e, why do they transfer heat more effectively than relying on convection/radiation alone?
In theory, they could cool the exhaust a small amount more than if you didn't have one. That shouldn't be necessary for a wood burner operating correctly. Could even be detrimental. It could, potentially, allow you to run an undersized wood burner hotter than it's most efficient setting. In theory.
In a small space, like the lounge of a narrowboat, yes.Are the little fans that sit ontop of a log burner any good?
This is our method too, leave door open to heat the rest of the house with the little fanMy log stove in the lounge doesn't need any help. It's enough kWs to do over half the house. Even a small fire has the room roasting in minutes.
Cooling flue gasses below the point at which volatiles can condense back out is bad practice and leads to chimney fires. If fans are effective at cooling chimney gasses significantly, they shouldn't be used unless you're already running the stove hotter than it's most efficient. If they're ineffective, fine, but they're ineffective. Maybe they have a place where you have undersized a stove for a space so are having to run it hotter than it is designed to operate efficiently at and a fan (or 5) allows you to bring excessive exhaust temps back down a bit. Possibly.for all the heat that is lost up a chimney and you lose loads as a basic stove is still outputting 1000f+ up a chimney fitting a heat exchanger on the flue adds more heat into a room that would be normally lost
you are correct but many think lowering it way too low is good practice on normal stovesCooling flue gasses below the point at which volatiles can condense back out is bad practice and leads to chimney fires. If fans are effective at cooling chimney gasses significantly, they shouldn't be used unless you're already running the stove hotter than it's most efficient. If they're ineffective, fine, but they're ineffective. Maybe they have a place where you have undersized a stove for a space so are having to run it hotter than it is designed to operate efficiently at and a fan (or 5) allows you to bring excessive exhaust temps back down a bit. Possibly.
(I know rocket stoves operate differently and flue gasses are safer to cool further but that's not what's being discussed)
