That's a win isn't it?That's no bad thing. The bacon ones are delicious but they chronically repeat on me, I burp bacon flavour for hours afterwards.![]()
Thats sort of standard, resistance is tested by outputting a precise voltage and checking the current delivered tho batteries might be done by instead drawing a load.An FNIRSI HRM-10 battery voltage and internal resistance tester:
View attachment 513169View attachment 513173View attachment 513174
Very impressed, so far. The HRM-10 doesn't need battery voltage to be present between the leads to measure resistance, and it will measure just about anything; welding leads, car jump leads, Li-ion or alkaline cells, or the resistance of a length of silver steel, for example. Also ended up getting the "round connector testing probe" cylindrical cell tester, and the double probe test leads, to go with it.
seems they can die quite rapidly.
It's basically the classical four terminal low resistance measurement technique. This meter seems to work by injecting current at ~1kHz, using one terminal on each side of the Kelvin clips, and measuring the voltage waveform that occurs in response, using the second terminal on each side. The resulting resistance readings are surprisingly stable, and resolution is down to 10 microOhms. It was able to pick up a slightly loose clamping screw fault in a welding lead.Thats sort of standard, resistance is tested by outputting a precise voltage and checking the current delivered tho batteries might be done by instead drawing a load.
I was looking at one of their ossiloscope DMM's but a couple of reviews put me off, seems they can die quite rapidly.
Love that little anvil!Todays bargain from the charity shop by Chepstow train station, genuine Mole grips for a quid
I was tempted by the anvil but left it as I don’t have space for it![]()
Afriad not - I'm ridiculously short of storage space at my new place so I have to resist anything that I don't have a need forLove that little anvil!
You did buy it though, right?
I did the same on a CorsaHad to replace some of those for a plastic sill moulding, I just cut the heads of some old nails which were almost the perfect size and welded them in with the mig. Yes I'm a heathen.![]()
Kamasa well that takes me back, the original stuff 40 years ago sockets were made by ETC Look for Japan on the sockets, spanners by Heyco look for Germany on them, nice thin spanners
I believe they ceased trading then someone re invented the name but sadly lesser quality stuff.
That’s the same set I have, “acquired“ about ‘72 or ‘73. Mine are without the rust though, just plenty of dirt!I still have a set of Kamasa tin snips bought around 1980, they've suffered a bit in storage but still work OK
