Hope she says yesMight even try it on today
Not quite in your league, but I got a black and decker hammer drill from a skip, just needed a small repair and I'm still using it years later, and a 1/2" drive socket set, complete apart from the 15/16" socket, which I had.You can get good stuff from a skip.
I have a complete in bits mi16 engine, the liners don’t want to come out - bad sign…
Alloy, I believe you could use an old diesel 1800 block to make a more robust one, but I never tried.Ally or iron block?
The good engine then like mine!Alloy, I believe you could use an old diesel 1800 block to make a more robust one, but I never tried.
This oil retention is an issue for many 8V converted to 16V engines - Vauxhall small blocks suffer from it, so does the Rover M/T16 and I would guess many others.The good engine then like mine!
The engine was built for saloon car racing, same as the Vauxhall red top.
Only let down by a poorly designed oil system that trapped the oil in the head, it couldn't drain back to the sump quickly enough, leading to low oil level in the sump and that coupled with oil surge meant a short life for a lot of these engines!
With a few simple modifications this fault can be cured.
The later iron block engine didn't have the oil issue but it's a heavy lump of iron.
That being said a 306 GTI6 is on my car wish list!
That being a Craftsman drill, is it 240v? I know it has a 3 pin plug on it but Craftsman stuff, being Murican, is usually 120v.
Yes it is 240Volts.That being a Craftsman drill, is it 240v? I know it has a 3 pin plug on it but Craftsman stuff, being Murican, is usually 120v.
Apparently sold by B&Q in the 90's.That being a Craftsman drill, is it 240v? I know it has a 3 pin plug on it but Craftsman stuff, being Murican, is usually 120v.
I blame @MattF for mentioning biscuit jointers and putting the idea my head
You're welcome.
I raced the Rover engine (now there's a heavy engine for you) for years, took me a while to realize how much oil was not draining back to the sump - in fact it was a session the dyno that proved it to me...
Vince Mosley had sold me a pair of 45 webers, I'd made an inlet manifold (from stainless!), but the carbs were fitted with 34mm chokes. Well this damn engine would not rev beyond 6500. So there was I holding the throttles wide-open, swinging the dizzy, when suddenly me, the engine and the old H&F dyno were engulfed in smoke. So needless to say I ran!
When the smoke had cleared the cause was easy to see - the "breather" pipe I'd fitted to the cam cover had emptied the contents of the rear cam box all over the exhaust..
So then you start thinking "how much oil must there be in the cam box to make this happen?" And why?
Of course, it comes down to insufficient drain returns, but these returns are also used to vent the crankase, meaning gasses are going up whilst oil is trying to go down. Turned out 2/3rds of the sump contents would be in the head....
Sorry for the long winded reply, but it's a story worth telling I think.
Well, I didn't know that.Apparently sold by B&Q in the 90's.
But I did know thatThey do have 240V in the US, so not unknown to have 240v tools in the USA either.
, though typically for higher load stuff like tumble driers etc in domestic installations. In fact, my first ever compressor was a Craftsman. 240v 6.5 HP 60 gallon vertical tank. Bought it in South Carolina in early 2001 and flew it home in a C130 (perks of the job
