Today I acquired an extra 60hp.View attachment 509276
Is that flywheel HP or at the wheels?
My stripes were always worth 20HP, and the Matt black bonnet added another ten.....The cloverleaf does that![]()
Nope those are for equipmentGiven your airsoft addiction I thought you would be buying ammo boxes for your lipos.
Mito?Today I acquired an extra 60hp.View attachment 509276
Mito?
They made a 155Hp variant of it.
Turbocharged 1.4 16V T-Jet gasoline engine the same on Abarth Grande Punto SS, 595 and 695 but with different ECU but essentially the same exact engine
Someone else was on about one of these, paid the princely sum of £60 for this from the son of the guy who used to own our house, so it’s come home!
Had little use, I didn’t let the surface rust put me off..
View attachment 509274View attachment 509275
Be careful & controlled when you lift the arm up to make an upright saw table with it . It becomes back end heavy and is very very easy to tip it over backwards .Someone else was on about one of these, paid the princely sum of £60 for this from the son of the guy who used to own our house, so it’s come home!
I already have a low speed vertical bandsaw, converted from an old wood botherer by adding a reduction gearbox. But it doesn't cut long lengths, hence I couldn't turn this local offering down. It needs a new band, everything but the length setting stop is free and working, so that should be the extent of it.Be careful & controlled when you lift the arm up to make an upright saw table with it . It becomes back end heavy and is very very easy to tip it over backwards .
I've added an extra wooden leg at the back to stop this happening again .( soon to be a spring out metal back leg .
It took me ages to beat the dent out the wheel case cover and get it aligned again so it could close enough to trip the safety microswitch to closed and rewired the thing with new cables and the grommets that got broken from the apex over basement exercise.
Oh that's the biggest displacement F.I.R.E. engine essentially the same exact engine on my little Punto but with 200 extra CC .Yes, I've got a 2013 Sprint with the 78hp 1.4 8v. Not very powerful, but bulletproof and sounds nice. I've made a custom cold air intake and will hopefully be making my own performance exhaust (high flow cat + straight-through muffler) once my welding is up to scratch, then with an ECU tune we should end up somewhere 100-150hp. Fingers crossed!
It took me a while to realise that the bespoke bi metal blade I had purchased hadn't been synchronised at the weld join , instead of the teeth being running alternative off sets there was two perfectly spaced teeth with the same off set .I already have a low speed vertical bandsaw, converted from an old wood botherer by adding a reduction gearbox. But it doesn't cut long lengths, hence I couldn't turn this local offering down. It needs a new band, everything but the length setting stop is free and working, so that should be the extent of it.
And this caused what? A clunk every time it came around or worse?It took me a while to realise that the bespoke bi metal blade I had purchased hadn't been synchronised at the weld join , instead of the teeth being running alternative off sets there was two perfectly spaced teeth with the same off set .
French mole traps are the way to go......View attachment 509367
MWitA asked me "Did I have any toy windmills" to poke into the mole hills,
so I set her to watch a training video.
Now she wants a 12 bore ...![]()
