Not quite aquired, but found a set of Ford Pinto main bearing caps in my workshop. Now, I knew I had two blocks - a standard bore low miles Cortina block, and a 205 Sierra block - both have their caps on. So that means that I have, or at least had another block in there... Means I need to do some clambering around to find it. I also found a pair of 2litre heads and 4, 2litre cranks. Also have an American 2.3 pinto without the turbo head.
It's been a while since I did anything with the Ford pinto, can you tell?
