You need the papr-ready shell to fit the other bits into, i think engweld and/or weldtech sell them.I've just bought the A60 recently..really impressive masks for the price. I am kind of wishing i bought the papr kit. Do you know if it can be easily converted for papr or do you have to buy a papr ready mask?
If you are worried about the cost of a front lens, you aren't pricing your work correctly...you are really clutching at straws now to desperately try and promote the brand you claim you have no affiliation to...u dont think esab made a big mistake using expensive front plates ? theres no good reason for it
Don't feed the trollIf you are worried about the cost of a front lens, you aren't pricing your work correctly...you are really clutching at straws now to desperately try and promote the brand you claim you have no affiliation to...
Uh oh... argument as to why you are just plain wrong coming in 3... 2... 1...Yesterday I was at my bench doing some welding ,,, newer speedglas , I really must say you have to try on a new mask , the new speedglas does not lift as high as the old one , and it gets annoying , I went back to the older version ,,, if your shopping and you weld sitting down make sure you try a mask on sitting down etc etc
theres no argument ,,, I sat with the two of them side by side yesterday , the new one does not rest over center on your head and is always trying to fall down , if you adjust the side bracket more so it sits over center its rest position is too high for bench welding ,,,, the older grey headband , the one you cant get as a replacement was way better but probably not as easy to fit an add flow to ,,,, anyways it was just to illustrate the point that you really need to try a mask in person rather than buy off line ..Uh oh... argument as to why you are just plain wrong coming in 3... 2... 1...
Ok, they're twice the price of the 3M ones, fair point. But Optrel ones aren't much less either.![]()
ESAB Sentinel A50/A60 HD Outer Lens - Clear (Pack 5)
Replacement outer HD clear lens suitable for ESAB Sentinel A50 & A60 welding helmetsSupplied in packs of 5.www.weldtech.co.uk
Ultimately, the price of front lenses doesn't really make or break the profit of a job...
Sorry, mate - I wasn't having a go at you. It was a (poor) joke aimed at the resident speedglas champion.theres no argument ,,, I sat with the two of them side by side yesterday , the new one does not rest over center on your head and is always trying to fall down , if you adjust the side bracket more so it sits over center its rest position is too high for bench welding ,,,, the older grey headband , the one you cant get as a replacement was way better but probably not as easy to fit an add flow to ,,,, anyways it was just to illustrate the point that you really need to try a mask in person rather than buy off line ..
no prob ,,, its all subjective anyways ,,,Sorry, mate - I wasn't having a go at you. It was a (poor) joke aimed at the resident speedglas champion.
practice putting your mask down like you would a crash helmet ,,, big open bottom end flat on the table ,,, it prevents it rolling off ont the floor , prevents scratching the front lens cover , and best of all stops grinding dust getting inside ,,,, after thirty or forty years it becomes second natureWell that settles it...the new mask is this one courtesy of @chip
Will be having a play about for the next hour, get the setting dialled in to how I like them and see what's what.
Its already miles clearer than the sip, even after I proceed to scratch the brand new front lens as soon as I put it in![]()
Oh it wasn't when I was putting it down...I dropped my filler rod and leant down to pick it up and caught the edge of the benchpractice putting your mask down like you would a crash helmet ,,, big open bottom end flat on the table ,,, it prevents it rolling off ont the floor , prevents scratching the front lens cover , and best of all stops grinding dust getting inside ,,,, after thirty or forty years it becomes second nature
Can't thank you enough, this is the clearest mask ive used.Glad its of use to you![]()
So...turns out. While the SIP was nice to use and I could see a lot more though it than the cheap Chinese ebay specials...it is definitely not a true colour mask...or not a proper true colour anyway...night and day difference between the sip and this one...
