Memmeddu
- Italia Sardegna
Remove the flaked rust then boil the entire vice in waterAnyone got any advice on using citric acid to remove rust. I've looked ir up on the net. but found no definitive answer. I know some of you use ot, I'd like to know ratio of crystals to water, time, and do you add baking/washing soda to the solution?
It rust will react oxygen in the water changing its molecular structure from FeO3 to Fe04
Rust blueing process, and you can either choose to oil it and keep it blued or paint it with hammerite or whatever and oil the unpainted surfaces
It will not rust as easy and it's enough durable.
