Custom white PETG internal corner caps for 50x50 trunking to go in at high level in my garage
Slight curved edges on the outside means they fit with no need to fix.
Ill be making my own external corners and end caps too. The electrical place was closed on Friday (they werent supposed to be!) But doesnt matter when you can make your own and probably alot cheaper too.
Plus a small mitre box from black petg for cutting said pvc trunking
(From online .stl file which I modified size wise to suit)
Now you are just getting cocky.Look how far you have come from a beginner a few weeks ago.
Orangestorm giga multi head should do the trickYes I suppose ive learned alot in the past few weeks but still lots to go. It is a very useful thing to have around almost every day I think of something to print
At some stage ill be looking for another printer with a larger build area and possibly multi colours. But I want to keep using the one I just bought for a few months before upgrading.
Little adapter for friends industrial vacuum cleaner, metal handle is push fit into a shallow taper and hose side is fiction fit with the locking tabs
View attachment 504216View attachment 504217
How did I not notice thatFiction fit ?? Ok I give in, " whodunnit " ?
Can you post the dimensions of the adapter for I suspect that like me several guys want an adaptor to put on to various machinery and use it to put the vacuum suction tube in ( I have a TITAN saw bench that needs an adaptor making or buying. )
Might work better hitting it with lighter first, like a hot spoon through butterCut it with a spoon
