Onoff
- Sevenoaks, UK
got it fitted yet ?
bit of tin foil would do it as it was in a chop saw i had a few days agoFitted the new bits. Did as advised and left the original legs on the board. Never thought I'd say my welding is better than my soldering but there you go. Had to fire up the 25W iron as the old CS18 struggled a bit.
Went to put the lid back on and realised I'd not ordered a new 20A fuse!
Other than 20A/250VP it's also got "326" written on one of the end caps. It's white, like ceramic...HRC or something?
I had one similar in a welder and soldered a piece of fuse wire to the caps as a stop gap. I bet it's still in there.Fitted the new bits. Did as advised and left the original legs on the board. Never thought I'd say my welding is better than my soldering but there you go. Had to fire up the 25W iron as the old CS18 struggled a bit.
5 new fuses coming tomorrow.
(joking)hes working on the idea if you got a spare you wont need them as soon as you cant find them it will go wrong againYeah fit one, it goes bag, skip the lot.
find which ones causing the fault and disconect . get paid for the time and im off
all i say theres an earth fault on it scrap it or get someone out to look at it and that will cost you at least a 50 quid callout just to be told it aint worth repairingi get called out to rcd.s tripping regular .washing machines toasters kettles tumble dryers dishwashers cookers ovens hobs the full worksfind which ones causing the fault and disconect . get paid for the time and im off
