Elliot 10m, the next job for it is machining the dovetails on a very worn Myford ML1, maybe in another 8 years.What shaper you got?
Morning or afternoon?Elliot 10m, the next job for it is machining the dovetails on a very worn Myford ML1, maybe in another 8 years.
Yes, vacuumed as soon as I finished, I hate machining cast iron.Make sure you clean the bed thoroughly after doing that!!!
All that for an earth strap?Quick little get out the *&#! Job for my father...he managed to break one of these and they are only supplied with 1 per unit...priced them up and the minimum pack of 20 cost nearly £500 plus the obvious wait for dispatch...
Off cut of 316 and about half hour including set up for the taper and I've just been told it fits perfectly. M6 thread, 9.5mm total diameter and a ballache of a taper to clock in as its only 8mm long and the part I was given to take measurements off was bent and mangled where it sheared off.
pretty muchAll that for an earth strap?
pretty much
Neat job!
Most folks would just use a spouting bolt an nut.
