Memmeddu
- Italia Sardegna
I think soFor the slotting head?
Yes mate , pure coincidence I told him I had the head no tools and he came up with them ! LovelyFor the slotting head?
Two Delrin cogs for my Meddings drills, the smaller of the pair. Ebay seller, just over half the price of Meddings themselves. Just search meddings and Delrin to find them, based in Portsmouth. Nice chap.
I may 3D print the next lot, but I don't envisage needing anymore unless I unleash a numpty on my workshop.
I used my Vevor 20" 58cc cheapie chainsaw for the first time yesterday.View attachment 499133
Clone of an Echo cs2511 and brushcutter.
Side by side, its not identical, slightly louder but same engine design/character. I may be mistaken but it feels more powerful - but thats likely from the more open exhaust. I like it! Will give it a proper try tomorrow.
Dislike - bar nut retainging clips not included, and just standard bar nuts, it uses two of them.
Like - the on/off switch is a momentary, auto return to on switch. All saws should be this way.
3/8 full chisel chain as standard!
The 12" bar I'll swap to the Makita to test that. I've put the 10" Echo bar and 3/8 full chisel on the Clone 2511 for testing tomorrow. 12" may be too long for this size saw I think, atleast for what I intend to use it.
The clone also fired up first pull. Very easy start.
Only at low loads and keeping the revs down, I ran a couple of tanks through it cutting Firewood for my daughter.
Plan was to try to get it a bit bedded-in before giving it more beans on the Ash Tree that's got to come down.
It took about 20-pulls for it's very first start.... but once started once it seems there's a technique - couple of pulls with engine switch off to prime it, choke on & a pull or 2 to get it to fire, then checked off, a bit of throttle & away it goes.
It feels a bit smoother and crisper now it's run for a bit, so I'm hopeful I've done the right approach. I had to adjust the chain after the first thankful, but I suspect that's normal as things settle?
I dunno anything much about saws, but apart from a pretty high idle and it seems to like drinking petrol - so far I'm pretty happy with how it run (daughter is happy as she now has a large crate filled with cut logs too)
Great, thanks!Might be worth a watch.
Chances are your saw will need tuned.
Main manfacturers like Stihl and Husqvarna tend to tune their saws on the lean side to comply with pollutions regs.
Good for the environment allegedly but bad for your saw.
To start with it's down on power so you'll actually spend longer cutting and use more fuel.
If its running lean it will shorten the life of your piston and barrel.
Once bedded in it will need tuned again but do yourself and the saw a favour and give it a tune up.
The rpm meter is a handy tool but most of my tuning is by ear.
50-1 is the mix ratio for the oil. Try to use super unleaded if you can or E5 unleaded. Avoid E10. The more ethanol in the fuel the worse it is for 2 stroke engines.Great, thanks!
It's running a bit of a blue haze atm. Not sure if that's cos it needs bedding-in, or if I've been a tad generous on the 2T oil (won't do any harm for the first few runs).
I'll have to pull the plug and see how the fuelling is on it
No priming bulb on this saw no, just a choke lever. Hence the couple of pulls to prime with ignition off & choke out, fire/die then push choke in to start seems to work. (Choke is manual as far as I can tell, not auto release).Does it have a pruge bulb to suck fuel through the carb? The ones without need to be pulled to vacuum the fuel through so can take a bit longer the first start. Every tool I have will pretty much start first or second pull
6 presses on the purge, choke, pull, it should fire briefly and usually die. Throttle to release choke, pull again. Gentle throttle to warm up, start cutting, let it rest occasionally until its up to temp.
Chain will often need adjusting after the first few cuts and then likely good until a sharpen or many tanks of fuel.
Idle can be adjusted easily. Please be sure the chain doesnt run on without throttle.
Larger CC saws can be very thirsty!
Photos required![]()
Interesting. I suppose they are all generic Chinese stuff in slightly different clothes.Looks near enough identical to the Parkside 53cc I got last year. Good saw. Be aware when sharpening that the alloy casing holds heat for a very long time, longer than most and burnt me once!
@Kram
Not bad money if they work ok but I really like this part of the add
It looks like a Dyson vacuum cleaner inside![]()
These things tend to be much bigger and heavier than they look when you try to fit them in a family saloon.My first Scrap On roller cab. Used, just got it home needs a clean up but really pleased with it. Serious gravity in the toolbox it must weigh 200 / 250kg empty
