could it be as original spacer wasnt too short and that the original washer was machined with a rectangular piece underneath that matched the slot , the correct depth obviously to match that when nut tightened it did nt pinch up, giving clearance ?That's the original washer, not one I've made. In theory, that washer shouldn't ever be getting pressure/contact from the lever, in use. The underside of the lever is what contacts & takes any wear. That's why it seemed peculiar for the sleeve to be under length. That top nut & washer is merely to prevent the arm rising.
so I don't quite know what has gone on in this shaper's history.
could it be as original spacer wasnt too short and that the original washer was machined with a rectangular piece underneath that matched the slot , the correct depth obviously to match that when nut tightened it did nt pich up, giving clearance ?
You could make brass tipped screws to take up the play assuming there is no room for a gib strip type arrangement.Quite oft some change, repair or modification has been made to old machines. This one of mine, the housing for the tool holder isn't original. That's why there were some screws on the side of it, to take out a small amount of play, as there's a bit of sideways movement possible on the toolholder. I haven't refitted those screws, as they're likely just going to wear grooves into the toolholder over time. I'll likely make another housing for it at some point.
Made the sleeve with a closed end as the end of that screw is a bit battered, & it hides the now unused keyway.
Looking good!Another photo in slightly better lighting, so that it appears to be in a slightly less dungeonesque setting.
Wasn't planning on a tray, (I'd never even given it thought), but now you've mentioned it, I may. Looks like I'm having a shopping session for large baking trays.
Well lit dungeon that, think I spotted a fingernail in the mortarAnother photo in slightly better lighting, so that it appears to be in a slightly less dungeonesque setting.
As for colour, couldn't you have gone for teflon black stylie or even enamel type like this
I can see you arestruggling for space so out of compasion I will let you sell me that swinden for a ton , which I know is a kindness on my part but I don t like to see people struggle , corking job you have done on that shaper, love the original finish . all the bestAnother photo in slightly better lighting, so that it appears to be in a slightly less dungeonesque setting.
if keeping it all together I would bolt it through to some OSB/whatever, then you could pick the whole thing up and bolt down to bench when in use.
i like the flip over tops for that
