Show us a photo of your tungsten after a weld,
Looks more like a gas problem to me, not enough and or bad torch angle, it doesn't look like anodised to me, I haven’t come across anodised aluminium chequer plate, I will say this it quite often comes with an oily scum, and because of the Durbar it's difficult to rub with a rag that's got brake cleaner on it without leaving half the rag caught yo the plate
It sounds counter-intuitive, but the solution is to turn the amps UP. Go hotter, and faster. It'll wet out the fillet before everything gets too hot. You can't hang around with aluminium, you have to start hot and move as soon as the puddle gets going. If you can't form a puddle in a few seconds, its too cold.This is the most useful all-in-one alu TIG resource I've come across by miles, so adding my queries here.
I've come from welding almost exclusively stainless steel, and am part way through my first alu job after knocking up a welding cart for practice. It's all 1.6-3.2mm box section, and while it's all been a bit of a learning curve I have a hard time getting nice fillet welds, particularly on butt joints. Anyone got any tips on getting the root of the joint to wet out before the whole thing gets too hot and messy? Have tried messing with the frequency but I'm not seeing any consistent results.
I have wondered if that's the case, I'll give it a go with fresh hands today and pay extra attention to the arc length. Is it worth maxing the frequency out at 200hz or do I risk making blowouts more likely?It sounds counter-intuitive, but the solution is to turn the amps UP. Go hotter, and faster. It'll wet out the fillet before everything gets too hot. You can't hang around with aluminium, you have to start hot and move as soon as the puddle gets going. If you can't form a puddle in a few seconds, its too cold.
Edit : what do you mean, fillet welds on butt joints? Its either a butt or a fillet... I assume you mean fillet.
I do have pulse but I found it less useful than manually pulsing with the pedal. It's a Lorch HandyTIG 200 for referenceHave you got Pulse that can help slowing down it all falling on the floor.
Funnily enough I find stainless much harder to get nice results with than alloy.
High frequency is only useful for welding coke cans, you lose too much arc energy in the wave crossing zero so much. I agree that you don't need pulse, it's only really useful on outside corner joints if you're being lazy IMO.I have wondered if that's the case, I'll give it a go with fresh hands today and pay extra attention to the arc length. Is it worth maxing the frequency out at 200hz or do I risk making blowouts more likely?
Re: butts I mean square tubes that are a T-butt arrangement (rather than a mitred corner), of which I have many, particularly with thinner walled tubes butting up against continuous heavier ones, making my life extra spicy.
looking good thereBeen using 2.4 Zirc and E3, 25-30% balance and sitting at 120hz right now. Have been running these joints (3.2mm base/1.2mm leg) with 160A max, the advice has definitely helped ta!
I have the same set, handy tig 200, my favourite welding set bar none.
