In normal mode instead of A frame it goes 3x higher. Im ok at this height!Just watch you don't end up recreating the Fargo wood chipper scene! That's an awfully tall ladder
Have you got it out yet? Is the hole an oiler for the gear wheel and the screw retains the shaft?This is the cover:
As it doesnt actually do anything other than hold the line stationary over the clock wheel it is not mission critical.
What is going to be a deal breaker is this small idler wheel that I need to transpose onto the new housing. Snag is, it is tight and I don't know whether it screws all the way through, Left hand Right hand, also it is brass. Any suggestions anyone @pressbrake1 do you have any suggestions?
Screw is on the outside:
Slightly better shot of the idler:
Does the hole in from the edge carry a pin do you think?
All helpful suggestions gratefully received.
Probably be the gate drive circuitry. If the part is rated for it (bear in mind that suppliers often quote misleading numbers) then either it's not sinking heat effectively enough or it's not being turned on fully and thus acting in a resistive manner.I made a mosfet reach 150°c in 10s lol.
I attempted to repair a perfect draft PCB as mosfet had fried and after spending several hours sorting wire jumpers as the tiny horrible traces kept ripping I managed to get it all set and good to go however it appears something else is fried on the board as just instantly blew these mosfets even though I ordered 50a versions to replace the original 30a.
Oh well time to find a donor machine!
Vacuum cleaner!Drilling Jig
I have a job for Mrs Miller that requires about 25 right angle brackets, about 30x8x180 (before bending) with 4 5mm countersunk holes in each.
Didn’t fancy measuring, marking, and centre punching each hole so I made up a jig.
View attachment 496195View attachment 496196View attachment 496197View attachment 496195
Just a few bits of 25x3 flat bar I had kicking about, and a bit of 6x2 left over from the bench build. Which was in turn left over from the shuttering for the shed build in the last house. I like recycling stuff!
The clamp was picked up from a flea market about 35 years ago.
The idea is that you pop the workpiece up against the stop at either end, clamp it down and drill it. Then release the clamp, slide it to the other end, clamp and drill. Then flip it over and repeat the whole process.
Swarf extraction system for the countersinking
Certainly seemed to work ok. I have another batch of larger brackets to make up soon, and there’s plenty of room on the same bit of timber but next time I’ll drill some holes at either end to let the swarf fall through as it tends to mess with the positioning somewhat.
Yep - a good old Henry. Rescued from my neighbour’s car boot just before it ended up at the tip! Just needed a replacement switch.Vacuum cleaner!
Yeah I think it might have lost a component the first time it's overheated since it melted the solder, just keeping an eye out for as cheap second-hand machine or a new board is about 70 euro from FranceProbably be the gate drive circuitry. If the part is rated for it (bear in mind that suppliers often quote misleading numbers) then either it's not sinking heat effectively enough or it's not being turned on fully and thus acting in a resistive manner.
MOSFETs are generally used either fully on or fully off. If they aren't turned fully on then the drain source connection had some non negligible resistance and thus heats up when current flows.
What's the machine?Yeah I think it might have lost a component the first time it's overheated since it melted the solder, just keeping an eye out for as cheap second-hand machine or a new board is about 70 euro from France
Phillips perfect draft hd3720What's the machine?
I decided I needed a square thing so I made one in case I need one .
Not much welding involved, but a fair amount of drilling and tapping to attach four 50W resistors to a big heatsink.
