I mean I'm certain going to be busy as only expected ~150 peoplePlease keep us upated on this, it needs its own thread with all the details. I would like one to play with when its ready![]()
That's a superb result!
That one of those in the tailstock auto disengage devices for repetitive accurate rod end threading?A friend, John Friar ( @Migmac ) called in and handed me in this as he did not know what it was:
Very kind of him.
Very rare to find them in the noxA friend, John Friar ( @Migmac ) called in and handed me in this as he did not know what it was:
Very kind of him.
You won't regret it. They make greasing , a nicer task. I would recommend a coupler, that you can press to release, ( Google g coupler) to make it easier to remove hose. You can put so much pressure, into a blocked nipple, that you can knacker the end, trying to get it off, because they are so tightI seem to get through grease guns at an alarming rate so when the latest went on the blink I thought I would give one of these a try.
I know JF, decent guyA friend, John Friar ( @Migmac ) called in and handed me in this as he did not know what it was:
Very kind of him.
Thats great! Like the test video.
Nah they were for prototyping, I've got a company lined up to do the lot recommended to me by other climbers who used them.Thats great! Like the test video.
Are you using JLCCNC to produce them?
Is this the first proper retirement project?Not today, but very recently acquired around 40 tonne of sandstone hard-core.
About 20 tonne in this pic so far.
I'm using sandstone rather than limestone as it's cheaper and good enough for it's intended use, plus the driver is local and can get it to exactly the spot I want. 6 or 8 wheelers can't and the drivers usually complain about getting to the location, their clutch, their hand bag etc
I have a rare bit of flat land behind the barn, but it's just earth on random building rubble. Vehicles like my bobcat sink in it as it attracts rain from the sump on the road nearby as it blocks frequently. The run off then seeps into the barn. Its also near the chicken shed and ideal for rats to live in. The barn is full of logs seasoning in IBCs, trailers etc. so can't do much in there.
So the plan is to dig this area out of most of the topsoil, this will be used to make a small terrace in the field. The hard-core and subsequent concrete will make a 25m x 3m mainly flat area, but directing water away from the barn into a channel that takes it to a stream. Then I'll build a lean too on the side of the barn for about 20m of it to store seasoning wood and trailers. It's quite secure back there as there is only one way in/out to block. Also a place to put the Bobcat when I'm using the barn for spraying.
