We are building an agricultural steel framed building.(animal shelter) Due to planning issues the height of the building needs to be reduced by 2 feet. The easiest way to achieve this is by cutting 2 feet off the uprights. The uprights are 178 x 102 x 19 UB with a 8mm thick 300 x 200 plate welded to the bottom.
The uprights will be bolted to 400mm of concrete before being encased in another 700mm of concrete.
I now need to cut 2 feet off the stanchions before welding the bolting plate back onto them. What would be the best process to achieve this. Arc or Mig? The work will be done in the workshop so shielding gas blowing away is not an issue.
I own a Esab Rogue ES 180i arc welder and an Oxford Migmaker 301. However, I have not really welded anything over 5mm thickness.
The bolt plates on the stanchions are not structural as they will be encased in concrete, but I would still like to do it properly. Had they not been encased in concrete then I would have paid a coded welder to weld it all together.
What would be the better process to achieve the best result?
Many thanks.
Many thanks.
