qwakers
- cornwall, united kingdom
paint in progress....front arms cut off ready for the 'new' ones from a breaker that had had the recall done.
Should have asked on here.New driver in, on offer for 40 quid, it's four ohm impedance like the original but I couldn't find a Wharfedale, new or second hand.
That one is 8 ohm impedance but close!Should have asked on here.
Picture is from about seven years ago, I built a big enclosure but never got around to buying a crossover. The plan was (is!) to get an active crossover and run it off a dedicated amp.
diff paintedand painted.
" Bend all the valves ." . timing chain failed at some time or other? Any marks on the pistons ?On with salvaging my lads cylinder head, quite impressive really he's managed to bend all the valves lol.
Luckily it's straight (checked with straight edge and feeler gauges) so no need for a skim.
hubs cleaned up and everything reassembled... just awaiting £200 worth of new brake pads...front mostly assembled but none of the arm bolts are tight. will sort that when its on the ground.
and rear subframe fitted, just waiting for the bushes and camber bolts to arrive.
all paintedhubs cleaned up and everything reassembled... just awaiting £200 worth of new brake pads...
driveshafts cleaned up, wire wheeled, abs rings knocked off and primed.
and the subframe mounting braces that i forgot to paint also....
