Printed that orientation for a smooth internal face? Might have been quicker flipping it and using pla/petg/pla interface or sharpie pen interface trick?Making a storage unit for my Easychange tooling but didn't like the rubber grommets' they had before so a few lucky measurements knocked these up got 23 to print so doing in batches
They are threaded underneath and got to print out the nuts next but very pleased with the fit
View attachment 486396View attachment 486397
Yeah i should have flipped it really , originally they had a solid bottom so made sense to do it this way but agreed there was a better wayPrinted that orientation for a smooth internal face? Might have been quicker flipping it and using pla/petg/pla interface or sharpie pen interface trick?
EnjoyYeah i should have flipped it really , originally they had a solid bottom so made sense to do it this way but agreed there was a better way
whats the sharpie trick ?
I use Orca for slicing, its free, open source and works with my Creality printer.Not sure if this is the right place to post if in the wrong place please advise me & give the correct title .
Wed 13 March 2025 I'm due to have my left hand cut open and see if the trigger finger nerve pressure can be eliminated so I can get better use of my left hand . Likely to be 6 weeks before I can reasonably use it . Then a few weeks later I'm likely to be called forward to have a reversed complete left shoulder joint replacement joint done . It's then likely to be a five to six months rehab afterwards , providing I escape getting Covid , septicemia etc in the hospital .
I want to use the nine months or so down time to relearn 3D printing. I've got my own Prusa 3i S and numerous sealed bags of Prusa's own filaments . I had started using Fusion 360 ( as a student freebie ) but several episodes of Covid and long covid knocked it on the head for me .
Happy to pay ( But would rather not pay ) for a programme that is similar , any suggestions from you who are currently 3D parametric drawing, slicing & printing etc.
You can still use it for free as a hobbyist - it’s what I use. There aren’t any significant limitations in the free version as regards 3D printing (I have it set to transfer to Orca for slicing and printing).I had started using Fusion 360 ( as a student freebie )
<snip: fusion needs a powerful PC>
It used to be, possibly still is, that fusion was designed to utilise a gaming GPU for the processing, rather than the CPU, so your 13th gen i9 may not be suitable if you are just using "onboard" graphics, rather than a separate, powerful, card?
Case in point: my "shed" pc is a 15y/o gaming PC - fx8350 + r390 GPU - and it still runs fusion at a usable speed.
Fusion also seems to require a lot more power (judging by how often the fan comes on and what process explorer shows), despite the fact the PC is ridiculously powerful (i9 13th generation) with loads of RAM (64 GB).
Finally finished my Easychange collet holder for the Bridgeport
Now it is done, consider the benefits from a debris-collection point of view of turning everything upside down. Or print some hats for everything.
All the ER holders have a decreasing taper the way they are shown, so anything that falls in will collect. With the Easychange taper, if that is uppermost, it is an increasing taper, so will shed anything that falls onto it.
Sandwich/lunch tray.
Mounts to (one of) the phone mounts.
The arm is a RAM style 1in ball system.
Screws into the fascia, then a home-designed socket (the brown one)>
An arm made from 20mm conduit + home-designed clamped-in ball ends>
A long Temu supplied alloy socket>
then the phone mount.
All printed in PETG.
View attachment 487295View attachment 487296
