My Old Landy
Engineering Mayhem
- North Lincs
Me too but they go for a couple of hundred these days!I had the metal one of those when I was a kid
If it's mint in box they can fetch around £600 (well that's what they were asking at the toy fair a couple of weeks ago).Reasonably certain I've still got mine in the loft, along with quite a few other 70s diecast SF models.
I have seen them as low as £60 but in quite poor condition. There are reproduction ones at £120 on Ebay and Amazon.
Not seen that file before..Well finally got Orca and Creality splicer working, wanted to give the K2 a proper workout so have printed the Clock spring torture toaster.
Spliced it in Orca, took just under 6hrs to print with a 0.16mm layer height. Probably could have used a .2mm
Over all its pretty good, the gears all work nicely and the apart from the 0.1mm slider the rest were easy to get moving.
For an out-of-the-box printer with no fine-tuning, its bloody impressive.
few little niggles,
First layer was a bit generous and took ages to weed out.
The 80 deg and 70 deg arms have a bit of distortion.
there is a small layer shift line on one corner.
View attachment 483795View attachment 483796View attachment 483797
This is a file i spliced, its available on PrintablesNot seen that file before..
Do the K2 files come preplated at all?
What's one of them when it's at home?View attachment 484051
New enclosure for Rpi GPS NTP Server
And GPS is global positioning system, NTP is network time protocol so it's a box that tells you where you are and what time it is. But more than that I don't know - maybe something to do with tracking satellites or stars /planets maybe??Rpi= raspberry pi
Beyond that...![]()
Slowly coming together, one bit at a time.
Now if those can handle a 10 kg load each and are stackable to six high you have a winner
