Brake pads are such a commodity, that, like so many other things, it's a race to the bottom, via a circuitous route of brand acquisitions and outsourced manufacturing.
I listen to a few business podcasts. The guys that are lamenting the death of manufacturing in the UK, are the same guys who are giving advice out to other businesses, to start importing from China in order to grow their business to the next level.+1 for the above.
Sad but true - but your quote of "it's a race to the bottom, via a circuitous route of brand acquisitions and outsourced manufacturing."
Is just so accurate...![]()
My neck o& the woods and didn’t know Mintex had a factory around here.In tried EBC stuff in my first integrale and when they fell apart I never bothered again - that would be over 20 yrs ago.
Used Mintex as a mate worked for them and they were okay - and as BBA (as it was then) used some of our machines
But for the last 20 years, Ferodo have been excellent. Less sure about Brembo disks as I they did not not like all year round use. Current set seem okay though.
Unless you were a local, 20 plus years ago, you wouldnt have known there was a Mintex pad making factory in Birstall, West Yorkshire. We used to do a lot of their machinery other than the actual forming presses - and we returned them on occasion. If I recall correctly, entire plant was dismantled and shipped off to Spain - we used to get occasional calls for assistance.
I assume they are still off the M62 at Cleckheaton. As a callow design engineer, I turned up there with an experienced fitter to don some work . . . Fitter brought a drill to use . . . Fliippin' hammer drill! For drilling holes in metal!
Never taken anyone's word that they have everything needed since!
Used a different brand tonight on my own car, Allied Nippon rear discs and pads on my Freelander 2. I have used these before and they seem like decent quality. Once again these use stainless pad guides clipped into the caliper carrier. Unfortunately new ones not supplied with the pads. Cleaned up the old ones OK and re attached them. Two of the pads were a little too tight and needed a light tickle with the angle grinder so that I had nicely moving pads on both sides. Not to the same extent of the previous Pagid ones in my initial post though. I've no doubt most garages would just bang them in and not worry about it but hopefully spending a little time and effort will ensure they continue to function properly.
I've found that the cause of binding brake pads is more often corrosion under the mounting shims, rather than oversized brake pad backings.
The shims you describe have a 'slippy' coating and often a plastic conformal coating on the carrier side, the idea is to reduce 'chatter' and allow the brake pads to withdraw from the disc sufficiently to prevent brake squeal. As you know, the mounting shims should be changed with the brake pads to renew the 'slippy' properties - in most cases, the application of metal-loaded grease will just attract brake dust, causing friction and therefore binding of the brake pads.
Before the copperslip fans get involved, there are no car manufacturers that apply metal-loaded grease to the moving parts of braking systems.... with good reason. I've lost count of the number of adhesive brake pad backings I've seen slathered with copperslip!
Do you have a brake caliper file? It's a special file for removing rust and debris from inside calipers. You shouldn't require grinding new pads, I suspect it's not cleaning the calipers thoroughly enough. Having fitted possibly hundreds of sets of brake pads, I have never once had to grind a new pad.....
Oh I been fitting brake pads for 42 years and yes I have had to "dress up" some awful fitting brake pads in my time.
It's rare though you have to admit no?
If you find this is needed often then I suggest you buy your parts somewhere else!
Wish I saw this thread a few weeks ago, I didnt know Pagid were a ECP brand, tho I did know they are supplied by them to Halfords. Halfords were cheaper.
I had to use a file as they were oversize plus the paint lumps. Yes I should have inspected before leaving the shop.
ECP seem to supply all of the local mechanic business here, so thats a good reason to do the work myself and buy elsewhere! I shall avoid ECP.
and its always the cheapest they wantsame as my job they buy crap but it takes me longer to fit them
I think the ECP empire may be struggling.I run a garage and I buy very little from ECP now. They not cheap anymore - not cheap at all.
