Pigeon_Droppings2
- london
Are those the Kellogg's planes...I remember collecting those as a youngster.
I couldn't resist
I have no idea but the seller had those plus three Hurricanes. I only collect SpitfiresAre those the Kellogg's planes...I remember collecting those as a youngster.
Yea I think I recognise them...I used to collect cereal box tokens and send them off. The propellers would often break off in the postI have no idea but the seller had those plus three Hurricanes. I only collect Spitfires
Not only yours.Simply those three words are my downfall.
Start with a lathe - cheaper tooling, cheaper workholding, I'd even say easier to use and more useful in many situations.I've just figured out it's better not to get one
Send it to Hownot2 he'll test it to destruction, it won't provide you with any official certification but might be a bit of publicity depending how well it does.Certification would be great but unfortunately way too expensive and would cost more than any profit I make.
As Kram said it's a niche device so no specific test for it, it's designed as a "mechanical third hand" to grab the rope and increase friction, it isn't meant to be used on its own etc
How are you supposed to use them?
I've a bunch of them with a big lot of taps last year.
I have some coolant through ones too.
I already have one, with expensive tooling too.Start with a lathe - cheaper tooling, cheaper workholding, I'd even say easier to use and more useful in many situations.
I was almost tempted to sell them out because we don't even use them at work and I didn't know they can be used manually.Same as any tap, just a larger hole to predrill, m8 should be 7.4mm - 7.5mm depending on the thread engagement and material. As the thread will be stonger, a lower engagement will be ok in tougher materials.
This confirmed my thoughts.Manually is not ideal for machine taps but yes it will work.
Yea few others suggested that and I might, know someone who works at Strathclyde uni in Glasgow which has a very professional advanced materials lab that might be able to help more than my plan of simulating a fall factor 1 fall from a tree tomorrowSend it to Hownot2 he'll test it to destruction, it won't provide you with any official certification but might be a bit of publicity depending how well it does.
Use a top rope backup and video itYea few others suggested that and I might, know someone who works at Strathclyde uni in Glasgow which has a very professional advanced materials lab that might be able to help more than my plan of simulating a fall factor 1 fall from a tree tomorrow![]()
I use machine taps for nearly everything, by hand, lathe or cordless drill. Most good machine taps are HSSE/cobalt but very few hand taps are.This confirmed my thoughts.
True but don't forget climbing rope is dynamic and works best over a long distance so a 1m fall tied to a thick branch will be a pretty good test and probably just as sore as using a static rope, I'll prep some ice packsTrees are very bendy, so while its a good initial test the force will be lower than a bolt in rock.
Same here, I use them by hand, in the drill, or on the power tapper.Use a top rope backup and video it
Form taps give a better thread, I would like to get form taps for M4,M5 and M6.
I need a spark plug adaptor so I have ordered one of these, slight use OSG taps.
It appears they have 5 or so listings, and have sold a thousand + of these taps, all with good feedback. I can only assume a car manufacturer must be getting a new one out for every engine?
What else is m14 1.25, used for?
Well what is that?I keep forgetting to post when I get hold of a 'new' toy.
I'll make a resolution to catch up.
Latest was this, only bought it because it was only £10 via Amazon, and it is a Tend. Sorry, didn't give you a heads-up, and it's for wood too.
Well what is that?
