This confirmed my thoughts.Manually is not ideal for machine taps but yes it will work.
Yea few others suggested that and I might, know someone who works at Strathclyde uni in Glasgow which has a very professional advanced materials lab that might be able to help more than my plan of simulating a fall factor 1 fall from a tree tomorrowSend it to Hownot2 he'll test it to destruction, it won't provide you with any official certification but might be a bit of publicity depending how well it does.
Use a top rope backup and video itYea few others suggested that and I might, know someone who works at Strathclyde uni in Glasgow which has a very professional advanced materials lab that might be able to help more than my plan of simulating a fall factor 1 fall from a tree tomorrow![]()
I use machine taps for nearly everything, by hand, lathe or cordless drill. Most good machine taps are HSSE/cobalt but very few hand taps are.This confirmed my thoughts.
True but don't forget climbing rope is dynamic and works best over a long distance so a 1m fall tied to a thick branch will be a pretty good test and probably just as sore as using a static rope, I'll prep some ice packsTrees are very bendy, so while its a good initial test the force will be lower than a bolt in rock.
Same here, I use them by hand, in the drill, or on the power tapper.Use a top rope backup and video it
Form taps give a better thread, I would like to get form taps for M4,M5 and M6.
I need a spark plug adaptor so I have ordered one of these, slight use OSG taps.
It appears they have 5 or so listings, and have sold a thousand + of these taps, all with good feedback. I can only assume a car manufacturer must be getting a new one out for every engine?
What else is m14 1.25, used for?
Well what is that?I keep forgetting to post when I get hold of a 'new' toy.
I'll make a resolution to catch up.
Latest was this, only bought it because it was only £10 via Amazon, and it is a Tend. Sorry, didn't give you a heads-up, and it's for wood too.
Well what is that?
I got mine from TEMU as part of a parcel of things to make the minimum sale post free , IIRC it was half the Trend price and it looks identicalTrend Corner Chisel. Heads up, that's actually a good price, there.![]()
Can you put up a picture of your crucible heating device please ?Amazons, they skipped my delivery yesterday so had to reorder and cancel.
I wanted an easy start recoil for my chinese combi engine. Usually hate the things, but should save ripping my arm off. Reviews were mixed so I ordered three and will return the most expensive as they break, they appear identical so I have no idea which was what.
A chuck. Its 1/2" unf which should fit my parkside drill, but I really would prefer a 3/8 UNF to fit the Fakita, but not many go upto 13mm.
Mini induction heater pcb, smaller than I expected and the board appears good quality. It should be adequate for warming bolts or shrink fits using a power tool battery.
Cheap cruicible to try, smaller diameter and taller than my others, that may allow me to get more heat in and then melt a quantity of brass.
Interesting, can you tell us more about this.Mini induction heater pcb, smaller than I expected and the board appears good quality. It should be adequate for warming bolts or shrink fits using a power tool battery.
