arther dailey
- England
interesting . still prefer C section as its easier to protect from the dreaded rot.What most people don't realise is that the Defender chassis steel is only 1.6mm thick if I recall.
Yeah, it becomes a very different set of engineering decisions.They end up being much heavier to achieve the same end result. Also I don't think they tend to like being twisted the way that box section does. It's amazing to see how much the chassis of say a 110 flexes when you cross-axle it properly and yet it just carries on.
The Edison motors project has been pretty spectacular to date, they're not compromising at all on what they identified in their requirements phase.The tooling also gets ridiculous - look at Topsy from Edison Motors, their prototype logging lorry. Living in the rust belt of Canada meant that Chase wanted a single skinned C section chassis rather than two C sections welded together, nowhere in Canada had a press-brake big enough to bend up the channel required so it had to be farmed out to somewhere in the US. It ended up being quite a bit heavier than the double skinned variants if I recall but for him the benefits far outweighed it due to the amount of salt on the roads there.
True but I think they said there was one place in the US that had the capability so not that many options.In terms of the tooling, that seems like more of a prototyping problem...
you did wellWell, it's coming, I have got it apart, drained the diff, popped the knackered driveshaft out, and reinstalled a new one...
Unfortunately the ball joint is knackered, but it's taper is thoroughly seized.
Given I'm having to fix it on the only flat residential street near my house, I have to call it for the night I think.
Or take the driveshaft back out and go get a sledgehammer in a last ditch attempt to avoid doing anything really drastic.I regret my decisions.
Had I left the knackered one in place I could just about have limped to a garage and made it their problem.
Currently the pressed in ball joint will not come out, and has trashed my ball joint press trying.
Options are:
- take the wishbone out and take it to my mates house to use a hydraulic press, or
- lug my oxy propane down and try to pierce it and burn out enough that the remainder shrinks and can be drifted out.
Two smaller ones connected together to get you by?The clips supplied are the awful tension style ones, rather than the gigantic adjustable O-clip style, I don't have the tool, not would I want to keep them, so I'm going to chuck a huge zip tie on for tonight to get it out of the road then go buy a set of proper clips from the auto factors tomorrow.
FFS
Edit: Double FFS run out of large zip ties.
I've run out of all the big wide ones that will take the tension needed unfortunately.Two smaller ones connected together to get you by?
This is exactly why I won't fit that type as more than a stop gap, especially not because I will end up immersing the CV's from time to time.I've got the propper tool to fit those cv clips and even with perfectly clean parts easy access and what appear to be perfect crimps they end up leaking or coming off![]()
Alas the tank straps are fine (replaced with those exact ones in the summer).Not sure what exact model but Roughtrax have this,
Genuine Toyota Fuel Tank Strap - Front - KUN25/26
Original tank strap 77601-0K090 with rubber insulator - fits front of fuel tank only (S/Cab & D/Cab)www.roughtrax4x4.com
