The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
As pulled from a river.
Boiled in Citric acid and attacked with a wire brush.
On the Dibber we found a name Elewell.
Then given a wax coating when warmed.
i might have slightly overloaded my trailer with wall debris when taking it to the tip. by about 150%....
it'll be reet! turned into bugger when i went over a particularly aggressive speed bump and bent a axle so the tyre was cambered enough to be hitting the bodywork even when empty.
now the correct fix is to put a 1 ton plus solid axle underneath. the fix available to me is a porta-power and a sledge hammer.
its straight again... for now.
this is going to take a while.next thing workshop related is the need for more offroad parking. there's only one place left...
this took hours, the absolute gits that put this wall up used 6" block. who does that?!
another long overdue job was to get power out the front. if id had any sense when i was building up the place originally i would have put water out here too.. however that's not happening now, so just power it is.
and im powering it off a fused spur, so i can switch it off when not in use.
Bug ger!tried. no availability for the only full weekend i have off for my usual guy, and everyone else wants a fortune..
Is that VHT 18SWG or 22? Might need 2 coatsFinally I got the silencer off of my twist-and-go.
However, it was a bit manky.
I found a 1.5mm piece of scrap, roughly shaped to fit, and did a superb job of welding it to the rusty, perforated bracket.
Now for a good coat of VHT after its soak in phosphoric overnight. A good excuse to fire up the barby tomorrow to get it dry and nice and warm.
Could I make one small suggestion?Had a lovely Yamaha RD350 VPVS in.
Full restoration but none runner unfortunately.
My daughter learning the ropes with the carbs, she enjoys fixing stuff like her dad!.
There was a fair few problems that all mounted up to a none runner, mainly pulse coil air gap and then float heights..
Went for a ride yesterday, forgot how nice these were!, a lot more refined than the 350lc!.
I went in to check oil pump stroke ans found the oil tank line kinked and folded over, that could have seen his freshly rebuilt engine off in no time!, a GSXR1100 carb slide spring has saved the day there..
That long hair - keep it inside the jacket, tied back somehow. I've never seen in real life the horrendous effects of long hair being caught in rotating tools that we were shown films of in the first weeks of our engineering course many years ago, but I have heard it once from a distance. She might not be using rotating tools now, but get into good habits early so they stick.
