Won a long battle.
Had a Ryobi brush cutter in repair for months due to my kidneys, hospital, getting after surgery, return to work, attempting to resurrect my YouTube channel because I've focused myself on my own health only.
Anyway back to the subject I've replaced sparkplug, ignition coil, carburettor, fuel lines .
Despite all that it wouldn't start.
So today I've emptied the tank put fresh gasoline, nothing to do...
Still wasn't going to start disassembled, perfect cylinder wall, no scores on the piston, good piston rings.
But seemed like it was having blow by, I've cleaned up everything, reassembled .
Still not running yet.
I've took the spark plug out, moved the piston to bottom dead center.
Used an heat gun blown hot air through the hole till it wasn't smoking anymore from the muffler.
It was clogged like nothing I've ever worked on.
Started first pull let run without cooling till no visible smoke was coming through the exhaust.
Stop
Put the conveyor on , started, tuned the carb without air filter .
Little bit lean TBH but the air filter will reduce the air coming in and increase little bit the fuel .
Anyway it's running now.
Can't wait to give it back to customer
That's a great tip .Clogged exhaust silencers / mufflers is often missed by many so called experts . I often carefully took them off machines and then used the oxyacetylene torch to get them a dark cherry red so it not only burnt out oily deposits it also ignited most of the carbon clogging the drillings in the interlan hard to get at bits. Once nice & hot they self ignited for a few minutes in which I kept tapping them with a bit of old broom stick to knock the difficult bits off the metal and giving them a waft of the torch now and a gain .
I'd then drop the still very hot silencer in cold water to cool it and also give me something with which to swill out th internals at both ends . Then reheat to evaporate any water , when cooled 7 totally dry a quick spray with alu paint .
Nice one!Plasma cut some 8mm steel.
Edge quality from the Jasic still impresses me
Got it tacked up.
Fully welded and rollers made and fitted ready for a test.
Not collapsed so far with 5mm stainless and there are no marks or scrapes at all, seems to be a success, now to design and adjustable one
It couldn't be avoidedMy nephew, newly divorced, a bit down & heavily into red wine. Sat down in his lounge one night and a mouse appeared. Fetched his air rifle, sat back down, took aim.....and promptly shot his flat screen telly.
Wasn't watching a bit of late night Bagpuss was he?My nephew, newly divorced, a bit down & heavily into red wine. Sat down in his lounge one night and a mouse appeared. Fetched his air rifle, sat back down, took aim.....and promptly shot his flat screen telly.
I'll be honest with youI'm glad I live where it's too cold for cockroaches. And the cats take care of the mice, and the hedgehogs eat the mice they leave.
Get some super sticky double sided sticky tape of ALIEXPRESS put a few strips of card with it on by the edges of the room , no light on then flick the lights on , the clatter of their shells & legs as they cross the floor to hiding places is amazing and the super stick tape is strong enough to hold any that try to cross it ,I'll be honest with you
It's been so hot that even roaches disappeared.
Rained maybe three days ago and they started to come out everywhere.
I didn't try uranium yetGet some super sticky double sided sticky tape of ALIEXPRESS put a few strips of card with it on by the edges of the room , no light on then flick the lights on , the clatter of their shells & legs as they cross the floor to hiding places is amazing and the super stick tape is strong enough to hold any that try to cross it ,
On a military base in Germany in the 70's doing a security /fire patrol I put the lights on at 3 in the morning in the cookhouse, only to see the whole floor covered in a light brown moving carpet which disappeared within a couple of minutes . This was about a week after the pest control guys had sprayed / fumigated the place . Cockroaches are able to live in a radioactive area that would kill a human within a few days & still manage spread all manner of diseases. .
, but I've understood roaches are pretty tough...
