It's not toeing in, it's toeing out, I had a brain fart and misread the specs and results.A toe in is certainly not going to help. Without seeing your data, I would have set the front up parallel with any tolerance towards toe out.
I had an MGF and it is a common issue. Try http://mgf.ultimatemg.com/group2/common_problems/epas_reset/index.htmit’s bad enough to prevent the steering from fully self-centering
That is not the same fault I have.I had an MGF and it is a common issue. Try http://mgf.ultimatemg.com/group2/common_problems/epas_reset/index.htm
That's correct, no matter if I turn left or right, the wheel does not fully return to centre.Is yours not self centering from both left and right turns then?
That was the R4, and it was designed that way., (one side short it did not worry some old Renault's)
An unhelpful answer as there is more than one variant in that series of falken tyres.Falken Ziex, the go-to ones at the moment.
Wozza I can't remember if you've already said but has it always done this.
My mate said they are VERY sensitive to tyres and tyre pressures.
185/55 15 Ziex ZE310 ecorun XL on the front, and yes!An unhelpful answer as there is more than one variant in that series of falken tyres.
I shall assume that was born of fustration.
Try tyre pressures from say 3 bar downwards in 0.2 bar steps ( 45psi in 3 psi steps for those using old equipment )
If it makes no difference then at least you've ruled out tyre pressures.
I'm suggesting pumping them up hard enough to balloon them and reduce the contact patch to see if the self-centring or lack of is affected.30'd be plenty I would suggest on the fronts. And parallel toe in/out.
ive had this before with a seized universal joint.
Scrub radius out?Well that was a waste of £70
It still doesn't properly self-centre with the replacement column so back to the drawing board.
Hey ho, at least I have a column to sell.
