Falken Ziex, the go-to ones at the moment.What tyres are on it ?
MGF is known to be very sensitive to tyres and tyre pressures.
Only trying to help...A change of tyres won’t create this problem, I know that for certain. I’m simply trying to get to the root of a problem I’ve never encountered in any of the god knows how many hundreds of cars I’ve ever driven in my life. I’m a mid 50s ex-mechanic, not just someone who’s owned a few cars, so give me some credit for at least having a bit of mechanical knowledge please.![]()
I know, and I do appreciate it.Only trying to help...
No, I only changed them today but the tracking can not have changed.I take it you've had the tracking done again since changing the upper ball joints?
Where are you seeing toe out?
According to this information the setting for tracking is not 1mm toe in . The correct setting is 10minutes toe out +/- 6minutes . As to what that works out to in mm depends on the diameter of the wheels. Nothing else you have tried works so what have you got to lose by trying these settings ?
Not unless it’s made with the pin off centre to the thread.You'd be surprised.
No it doesn’t clearly say toe in! The - before the 0 indicates toe out, if it was + it would be toe in . Your castor readings are a bit short as well as shown on one of your previous posts which isn’t helping.
I know, I did post an apology above.No it doesn’t clearly say toe in! The - before the 0 indicates toe out, if it was + it would be toe in . Your castor readings are a bit short as well as shown on one of your previous posts which isn’t helping
If I place two pieces of timber parallel to each other, measure the distance between the ends then turn them towards each other by 1mm, the distance between the same ends is -1mm of the original value. That's how my brain was interpreting the toe data.Oops! Seems I owe an apology to few of you. My brain has been reading minus as IN but apparently for wheel alignment data minus is OUT for toe data![]()
I was just saying that's how my brain was interpreting the plus and minus.Not exactly, the extra length of the wood over the diameter of the wheel where the tracking gauges would normally fit will have an effect. Imagine extending the wood even further the reading would be exaggerated. Some garage computer programs translate the readings from degrees to mm or the other way according to the wheel diameter . It would be possible to do a bit of trigonometry to come up with the correct reading , I could have done it 50 years ago but would struggle now
Rear toe isn't going to affect self-centering of the steering, but it will make quite difference to handling - toe in on the rear of my Lancia is a standard setting for safe handling. Straight makes the rear more nervous, toe-out means opposite lock at speed!
I would have thought front toe-in/toe-out difference you have won’t cause the steering to do what you feel it is doing - although it would affect actual cornering performance.
The general handling is superb, it is absolutely pin sharp on bends.
Castor does look a little less than ideal on one side, within tolerance the other (if I remember the figure from earlier posts) - but I can’t see it doing all you say - it would maybe slow self-entering effect, but not stop it. Is the effect the same in each direction?
Yes, exactly the same both directions
I think you’re going to have to remove the column for a proper look - that or the driver’s seat so you can lie in the footwell and look up - see if you can spray something suitable into the column so it runs down the shaft into the bushes. I wouldn’t use common old oil - some nylons do not like it.
I've already replaced the column but it made no difference.
Is it possible to unbolt the electric assistance from the column to remove the chance of a mechanical issue with it? I think you’ve already tried it electrically disconnected to rule out the ECU?
I've pulled the EPAS fuse and it makes no difference. The replacement column also came complete with the EPAS system. I don't think it's possible to remove all the EPAS stuff and retain a usable column
It is amazing how something relatively small can make a massive difference - years ago steering on my Spitfire based kitcar lacked self-centering, in-fact you could turn the wheel and leave it - it kept the lock on until you manually unwound it.
The UJ to the rack had stiffened up - it was enough.
Both lower column UJs are perfect
It’s not listed on the printout. I suppose I could measure centre of hub to centre of hub but the fact the caster is different both sides tells me I’d probably see a slight difference.Have you checked the wheelbase both sides ? Or was this done as part of the 4wheel alignment?
