For the self-centering to work, is that whilst driving, with the EPAS power connected ?It still doesn't properly self-centre with the replacement column so back to the drawing board.
Yes, while driving and it makes no difference if the EPAS is active or if the fuse is pulled. It had a 4 wheel alignment 3 weeks ago, the ride height is correct, the front tyres are new.For the self-centering to work, is that whilst driving, with the EPAS power connected ?
Could it be a wheel alignment issue ...?
I think MGF's have some issue with speedo or tacho signals and/or alternator voltage affecting the EPAS...?
All the steering geometry is within spec, according to the printout.If you disconnect the track rods from the front arms, then check for any binding or tight spots on both front suspension and the rack itself, I am wondering if it is an issue with one of the swivel joints, especially the lower ones that may have been tightened enforce the vehicle was sitting on the ground.
Or the caster angles are incorrect due to kerb or pothole interaction.
I don't believe so, I asked on a couple of FB groups and nobody said it was a common issue.Might be a silly question, but is it simply a feature of the TF![]()
I know what you mean about fun to drive. A pal of mine had one and despite it ny being the 135 (04 plate), point to point, it would easily out perform the wifes MX5 (05 plate, 1.8i sport).I don't believe so, I asked on a couple of FB groups and nobody said it was a common issue.
I wish I wasn't so far into this car, for a £500 buy it's become a bit of a money pit.
I do still enjoy driving it though, despite this niggle. It really is a lot of fun.
It’s not the PAS Brian, I’ve driven it with the fuse out and it behaves exactly the same.On my diagnostics system it has a steering correction facility, goes through the module and resets the whole PAS. Might be worth plugging it in and seeing if your model has this facility W.
With the track rods disconnected from the steering arms I can push and pull the rack from lock to lock with no obvious resistance and swivel each wheel freely.
One ball joint felt a bit iffy so I replaced it but the new one was tighter than the old one.
You might want to check the link out it seems the saved tracking settings aren't always correct.All the steering geometry is within spec, according to the printout.
